Question about Baby Lock Sewing Machines
Having trouble threads baby lock blse200, lower looper.
  • 185 Answers
SOURCE: unable to thread lower looper on Babylock Eclipse BLE1SX
On rare occasions lint can clog the yubes on these sergers. One of the first things I do is thread the wire through in the opposite direction. It will sometimes push the blockage out. The other option is to use an air compressor and again blow the lint out from the opposite side. If this does not work take it to a service man.
Posted on Feb 21, 2008
SOURCE: lower looper thread jammed in tube
my husband took a very thin stainless steel wire and very carefully put it through th eloop and the thread came out the eother end and and I could see how bunched up it was inside.
I hope this will help others
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
Posted on Dec 07, 2008
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
PRO LINE BABY LOCK SERGER, BOTTOM LOOP TOO LOOSE.
Make sure the lower looper thread is seated properly in the tension disk. (RAISE the presser foot. Grasp the thread between the thread tree and the tension disk and with the other hand, grasp the thread below the tension disk and give a little tug.) When threading, always RAISE the presser foot so the tension disks are released.
If the lower looper thread is still too loose, set it to a tighter setting until it creates the stitch you want.
Feb 27, 2016 | Baby Lock Sewing Machines
Threating lower left looper on baby lock eclipse
it's possible that a part in the serger is broken or damaged it need to be serviced by a sewing machine repair shop
Jan 24, 2012 | Baby Lock Eclipse Serger
I have been using my serger then suddenly it would cut and not serge. I am still unable to thread the "green" right hand threader.
Apparently either you have no needle threaded to lock the stitch or both loopers aren't correctly threaded. You must thread your UPPER looper first (don't know what color yours is), LOWER looper next, RIGHT needle next and last the LEFT needle if you are using the 4 thread overlock stitch. It sounds like you are having trouble with your lower looper. Look for the lower looper threader to help you thread it. Your manual should show you a picture.
Aug 10, 2010 | Kenmore 16622 Mechanical Sewing Machine
Where is the upper looper on Baby Lock Eclipse model DX
This is what an upper looper looks like http://www.tradekey.com/selloffer_view/id/3755146.htm
It is the one in the back and point toward the needles.
The looper in the front is the lower looper and points away from the needles.
Open both doors on the front of the serger and you will see the loopers to the left of the thread ports.
Mar 28, 2010 | Baby Lock Eclipse Serger
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
I've lost my manual and video need threading info
One of the most common mistakes with overlockers is that the threads must always be threaded in order. So if you sew about 1 inch and the thread breaks try unthreading the eyes of the needles rethread the looper and then rethread the eyes of thew needles. If not you will get the same result of sewing about 1 inch and it will break again.
Aug 26, 2008 | Baby Lock Ellure
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
May 25, 2008 | Baby Lock Imagine
Lower looper thread jammed in tube
Apr 28, 2008 | Baby Lock Evolve
Baby Lock Protege BL5370Ed Serger
I was in a similar position (but had the manual). The manual isn't as complete as I'd like. Anyway, what finally got mine working were the following:
1. turn all tensions to zero before putting thread through them
2. thread the upper looper, then lower looper, then needles.
3. when threading the lower looper (mine kept pulling out), after passing the thread through the looper eye, it needs to go pretty much straight up, not wrapping around anything else - other thread, for example. Mine was at one point trying to wrap itself around a post.
4.when everything is all threaded up, make sure all threads are under the foot *and* pulled to the left (even though the manual says pull to the back). Then chain off without fabric, turning the handwheel by hand to make sure loops are forming. If so, adjust tensions to where you think they should be (mine are currently all between 2 and 5), and add fabric. Then tweak as needed.
For me, this was a lot of trial & error, hair-pulling, and getting tips 1, 2, and 4. I figured out #3 on my own, with much swearing along the way. Good luck!
LF
Sep 24, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
61 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
