Question about Thinkway Disney Pixar Toy Story 3 Talking Sheriff Woody
Woody doll volume is low. Was OK yesterday. Is there a way to adjust the volume? We have tried new batteries, but no change
5 Suggested Answers
  • 3 Answers
SOURCE: Disney Talking Woody Doll - String stuck in pulled position
A friend of ours gave our son a hand-me-down Woody doll with no string at all. I decided to see if I could fix it...about 4 hours, 1 soldering iron, and the realization that my eyes are failing faster than I thought, I was able to return Woody's voice. I'm sorry I didn't take any pictures, but here's what you'll need to do depending on what you find as you operate.
0. Perform of these steps over some sort of container to be sure that you don't lose any of the small pieces that may be liberated in this operation (particularly a small spring that comes later).
1. Take out the battery pack through his lumbar Velcro. There is a black wire that carries power into Woody's thoracic cavity to a module that houses the electronics.
2. You will have to untie, or otherwise get the string through the hole in Woody's back so you can work on it...I don't know what's at the pull end of the string since the Woody we inherited had no visible string.
3. Cut open the white fabric inside Woody that separates battery pack from the electronics module.
4. Take out the two screws that hold the two halves of the module together. CAREFULLY separate these as there are a couple of wires that run between the half with the electronics and the half with the speaker.
5. If you are lucky, which I was not, all the wires will be intact and you will only have to restring Woody. (Nervous sytem work (i.e. wiring) will require a soldering iron and perhaps the assistance of an additional set of hands...)
6. The string is wrapped around a spindle which is spring loaded on one side (it's the big spring - not the little one). With the spindle side of the module towards you (big spring to the lef), the string *should* come up in front of the spindle, over the top and down through the hole..at least think it should. Again the string was broken in ours and once I opened the module, I couldn't tell which way it was originally.
7. On the right side of the spindle is the mechanism that completes the circuit when the spring is pulled. This includes a small spring, and metal piece that makes intermittent contact when the spindle winds back up after pulled.
So, depending on what you see when you take the module and battery pack out you may find:
0. Oh, of course, replace the batteries just to be safe.
1. The string was just hung up in Woody's back and simply removing the module allowed it to be come free again. Piece of cake.
2. The string was bound up around the spindle in which case you just need to clear it and be sure that it winds up properly when pulled. You may need to rewind the string, in which case you need to lift the right side of the spindle (take care to observe how the spring and metal piece are configured...and DON'T LOSE THE SPRING..it took my 10 year old daughter's eagle eyes 5 minutes to find it after it went shooting off the table)
3. The spring mechanism is somehow stuck. This will require tweezers and some patience to sort out the cause.
4. You may have to replace the string. I found some laying around the house that was close to the small shred that remained in our Woody.
5. Finally, I actually had to solder down 3 wires to get the circuit to work. If you're in this predicament, let me know and I will draw a picture for you of what goes where.
In the end, I got Woody to talk again, though he tends to speak without being pulled from time to time. But I gotta tell you, the feeling I got when he burst out with, "Howdy partner, my name's Woody!" was about the best feeling I've had in a long time.
Good luck, and let me know if you need any more information.
Shawn
Posted on Dec 26, 2008
SOURCE: How do i fix my sons woody doll.? String stuck in
no sound is coming out of woody when i pull the string
Posted on Sep 05, 2010
caroldon
  • 17129 Answers
SOURCE: Lennon Talking doll intermittently talks.
This is not due to any other fault than the sensor/ motion is triggered out of turn. It can be a dry/loose connection within the electronic unit. If you can get access through the battery compartment-- this is quite tricky as you might damage the doll if the clothing needs to be pulled out.
Unless the electonic section is checked the erratic operation cannot be confirmed.
Can be due to dry soldering in the board, if so a touch up of the suspected joints can be done.
Posted on Nov 01, 2010
  • 6 Answers
SOURCE: How can you repair/re-attach a boot on a Toy Story
be patient on that ... re-attach the boot by glue .
Posted on May 24, 2011
08 T190 Runs for 3 or 4 Sec. then stops and will repeat
Low charge psi. Check for fault codes by holding head light button for 3 seconds.
Dec 10, 2011 | RTO Construction Bobcat by Woody Click
My grandaughter's new jessie doll quit speaking. i don't know if it uses batteries or if the speach comes from a player energized by the pull of the string. is there any way to get the clothes off...
Truthfully, most of the time, you cannot take the clothes off of a Jessie doll. No matter what company, they will always stick to the body, including the boots. Sure, you can take the hat off, but not anything else. If she has stopped speaking, she needs new batteries. THANK YOU!
Aug 01, 2011 | Disney Toy Story Fire Fightin' Woody Pull...
Speaking volume is too low.
Is this a brand new toy? Usually the volume goes down as the battery dies, so you might try replacing the battery on it. If a fresh battery doesn't solve the problem, I'd either take it back to the store (if it's new) or if you have skills with a soldering gun, pull the board from the toy and mod the volume (instructions on how to do this are on instructables.com) Hope this helps.
Mar 14, 2011 | Toys
Missing hat for sheriff Woody. How do we find a replacement?
Have you tried ebay? Ive been looking as well and I can only find one there. I am finding its almost worth it to buy a new woody though at the prices people are paying for just the hat.
Feb 16, 2010 | Thinkway Toys
I have a bobcat 743b that seems to lack power on lift especially when it heats up
you might to get new batteries the might have been charged and discharged to many time
Jan 12, 2010 | RTO Construction Bobcat by Woody Click
Cannot adjust volume
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2008 | SanDisk Sansa m230 MP3 Player
Thinkway Disney Pixar Toy Story 3 Talking Sheriff Woody Logo
172 people viewed this question
Top Thinkway Toys Experts
ka4iup
ka4iup
ray gallant
Are you a Thinkway Toy Expert? Answer questions, earn points and help others
