Question about Canon imageRUNNER 2200
I need a diagram of where the toner over flow bottle is located.
  • Canon Expert
  • 287 Answers
Hello lynae,
I must assume you need help with the waste toner bottle. I would be glad to help. First lets establish a frame of referrence. We will start by assuming you are standing in front of the copier. If you have a stapler/finisher, release it from the copier and slide it as far away from the main copier as you can. Ok now you have exposed the area/panel that you need to access. The panel you need to remove is located at the left side of the copier, at the lower rear very back. The panel has one screw and is about 4 inches wide by 11 inches tall. Now it's not ON the back, its on the left at the lower rear corner. Remove the screw.Remove the cover. You will now see a bottle.It has a handle and is not clear but milky looking as far as being to see thru it. Slide the bottle straight out. Now we need to empty it. Get a trash bag and empty the bottle.Keep it low and slow so the toner does not poof out every where. It does not need to be completely empty. Now the way your copier knows(or thinks) the bottle is full is by shining a light through the upper neck of the bottle. Look closely and you will see 2 small "windows" that the light shines through. When those windows are dirty it blocks the light and the copier "assumes" the bottle is full. Although the bottle is empty, the windows are still dirty. Use a Q tip or whatever you can cram in there to clean those windows so the light can shine through. Once they are clean re-install the bottle and put the cover back on. Slide the stapler/sorter back to the copier {if you have one}. Unplug the copier. Wait a second, and plug it back in. If you cleaned the windows in the upper neck of the copier properly the light will shine through and the copier will be happy. TADA!!!! GOOD JOB! Take care and let "FIXYA" know I helped you please. SPINAL
Posted on Mar 15, 2011
Where is waste toner located in copier
In the past i have found the waste toner bottle is usually the same place as either the toner or the drum (mostly the drum) and will be a clear bottle. Possibly wide at the bottom and thinner at the top.
Hope this helps
Nov 07, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
ON THE NRG SP C222SF PCL 6 printer we are getting a code of Life End Waste Toner Bottle. I do not know what or where the waste tonner is. Please help
ok mate. i am a Ricoh technician. the waste toner bottle is located above the paper tray.take the paper tray out, then you will see a bottle inside on top of tray. it is flat and you have to pull it out and empty the waste toner from it. if you have any problems email me on ronils_singh@yahoo.com.au i will email you the diagram from service manual and the procedure.
Oct 01, 2010 | Office Equipment & Supplies
Erorr E000019-0000
the waist toner bottle is full or the waist toner bottle sensor has become blocked. if you know where the bottle is remove it, empty it and then clean off the outside bottle with a paper towel. becareful as the toner has a tendency to make a big mess.
Jun 18, 2010 | Canon IMAGERUNNER 2230 Copier
How to replace savin c3030 waste toner bottle
The used toner collection bottle is located behind the cover, just left of tray 1. To empty/replace this bottle, follow these steps.
  1. Turn machine off with red rocker switch, this is located on the left side of the machine.
  2. Open front cover.
  3. remove screw on the bottom-left side that holds the toner collection cover closed.
  4. close the front cover
  5. pull out tray 1
  6. open toner collection bottle cover(swings to the left)
  7. pull out toner collection bottle
At this point you can empty it or replace it, and reassemble in the reverse order of removal.
Dec 05, 2009 | Office Equipment & Supplies
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
Toner light does not go out after adding toner
Are you sure that the "plunger" located in the top of the toner bottle did not remain in the machine from the previous bottle? Sometimes it is not fully released when it is removed, and then it obstructs the flow from the next bottle. Remove the new cartridge, and look into the front of the toner hopper. All you should see are the "claws" that grab the bottle when it is inserted into the machine. If the "plunger" is in there remove it. Please let me know :)
Jun 04, 2009 | Ricoh 3310LE Copier
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
I replaced the Sharp AL-1642CS TD toner cartridges twice. Still flashes the toner symbol. Someone mentioned cleaning the toner sensor. Where is the toner senor located? drjanisch
Where the toner bottle inserts into the holder, make sure the OLD bottles nipple is not stuck in there, this issue will not allow the new toner to flow into the system and the machine thinks it has an empty bottle
Apr 04, 2009 | Sharp AL-1642CS Copier
Canon imageRUNNER 2200 Logo
126 people viewed this question
old marine
old marine
