Question about Maytag Dryers
Changed the power source on a Maytag dryer from a 3 prong to a four prong. Good power source and as far as I know, I've connected the wires correctly but I'm still not getting power.
  • Maytag Master
  • 8,220 Answers
Post yer model number I may can help ya diagnose that puppy.
Posted on Mar 15, 2011
We have a Maytag Neptune mde5500ayw electric dryer, with a three prong cord. Our new house has a four pronged outlet. I purchased the correct 4-prong cord, but need to know the proper way to wire it into...
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Maytag MDE5500AYW Electric Dryer
How do I connect the a 4 prong power cord
Four prong dryer cord connections to dryer:
- Red to far-left or far-right screw on dryer (doesn't matter which side)
- Black to screw on opposite far-side on dryer
- White to center screw on dryer
- Green to dryer grounding screw
Any questions, please let me know.
Oct 02, 2009 | Maytag Dryers
Three prong needed with four prong dryer
The following link explains how to correctly wire a four wire configuration on your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have any questions, please let me know. I hope this helps you.
Jul 06, 2009 | Maytag Neptune MDE6700A Electric Dryer
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Four prong plug to three prong plug
Kalola,
You can if you want to, but it's not generally necessary. Here's a picture of a 3 prong configuration with a ground strap...
That green wire with the yellow stripe is a ground and it is most definitely connected to the cabinet somewhere. So it will serve as the ground strap (in the above picture).
Here's the thing... say you were going from a 3 prong to a 4 prong. That is, the dryer was originally "designed" for a 3 prong. This means you'd have to "retrofit" it a bit. Take a look at this pic... ( I made this for someone else, so please disregard my somewhat hostile remarks, OK?)
The ground strap has been removed and has been replaced by the ground to the frame. Yours probably does NOT have a ground strap, though... yours uses that Green/Yellow wire for frame ground.
All of that to say this. Don't lose sleep over it. Ya done good.
SG
May 01, 2009 | Maytag Neptune MDE6800A Electric Dryer
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Changed from 3 prong to 4 prong power cord ,now theres no power.
Please review the following link:
Do you have your power cord wired correctly? Please read through the link thoroughly and confirm the wire color coding and the placement of where you have the wires terminated. I hope this helps you. Let me know if you have further questions.
Jan 04, 2009 | Estate EED4300SQ Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
I had to change the three prong wire and replace with four prong
If you are converting from 3 to 4 prong service, that is fairly simple and should be done as follows:
If you purchased a pre-terminated cord that has a molded plug on one end and four wires with lugs on the other then that is what you have to attach to your dryer. Start by pulling the dryer out far enough to gain easy access to the back panel. Depending on the model, you will need to find the place where the cord feeds through the back and feed the new wire through that opening ( there should be some kind of cable clamp that guides and clamps that cable through the back panel). Once fed through, look for the terminal block on the back of your dryer. You will have at least 3 terminals that should be color coded red, black white or green) Start by installing the red to red, black to black and white to white ( or green) and then take the green wire end of the cord and look for a ground stud on the back of the dryer. There should be a terminal or sheet metal screw that you can attach that green wire to the dryer. The green wire is a safety ground that bonds the dryer to earth ground and provides a path to ground through the dryer chassis should you develop a short top ground. That path is provided to protect you so that you don't become the path from power to ground. Hope that helps...
Just remember to do all this wiring with the cord unplugged from the power source...
Regards,
Rick
Nov 23, 2008 | Maytag Dryers
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
