Question about Health & Beauty
Machine will only print leads I II and then machines seems to hang up and stop printing.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 66 Answers
Hello Dear
Its seems too be the problem of your printer, or the printer head.
Replace the printer if possible or clean the printer head by printind head cleaner. And run the machine if the problem exsist then change the printer.
And Check again. If it starts printing then its the printer problem.
If it dont then there is a machine problem.
Regards
Posted on Mar 15, 2011
How to mix words with music, poems
This seems like normal operation for any printer, but if you do require it to come out differently, before printing make sure you set the correct orientation and print preferences in the application you are printing from before you print.
This menu can also be found in control panel > printer and right click on your printer and select properties
from here you will be able to fine tune all of the settings on your printer.
May 24, 2013 | MicroBoards 554364-106 Rimage PrismPlus...
The machine prints Lead I but nothing else. What should I do?
Your print head probably needs adjust. The Schiller ekg machines are notorious for these issues. You may want to send the machine in. We/ Discount Cardiology will look at your machine for free and call you with a diagnosis. I am 99% sure that this is the issue.
Aug 23, 2012 | Schiller Welch Allyn Cardiovit At 2...
I have an at1 schiller it starts to print in auto mode for like 6 seconds and then stops sometime it prints the full report and sometimes it dont can u assist
hi,
You have to check two things. First you have to check the patient cable, and have to check is its electrodes are properly cleanded or not. if any one of the lead or the electrode have some problem then the machine will stop printing.
Second thing the battery inside the machine. its a 12V 2.3AH battery. If availabel try to replace the same. To replace the battery you have to oppen the machine.
ok
Jul 06, 2011 | Schiller Cardiovit At 1 Ecg Machine
Schiller AT-Plus, I cannot get all leads to print in sequence I avr v1 v4 II avl v2 v5 III avf v3 v6 not sure what a student did to change the...
The unit is apparently printing out in Cabarra sequence. To restore the correct lead sequence, do the following: Hit the ALT key followed by 7 then 1, hen the stop key. This will restore standard lead sequencing.
That is the start of the battle. If you desire a 3+1ryth format with a lead 2 at the bottom, which is our standard format, then you have more to do. For this format hit the ALT key followed by 1 then 0 followed by the stop key.to set the ryth lead to lead II at the bottom of the page, hit ALT followed by 3 then 8 then 2 followed by the stop key. If your filters are not enabled hit Alt 5 6 stop, alt 5 8 stop, Alt 8 3 stop, ALT 8 1 stop.Do a test print after all of this and be certain the unit is configured to your taste prior to a live patient.
Jun 14, 2011 | Schiller Welch Allyn Cardiovit At 2...
Personal Wheelwriter II: I think there is a code to make the letters strike harder - (Darker)? kalbertson@greencountywi.org
Code "I" will change the impression but more likely the print solenoid cap is cracked, if so it will shortly stop printing. We sell the cap with shipping and instructions for 20.00
DickyO
Cleveland Business Machines
216-241-0027
Dec 09, 2010 | Lexmark Wheelwriter 6 Series II Typewriter
I ahve a schiller welch allen EKG machine, and now it only prints
If it stops printing completely in the middle of doing the print, it is because the battery is bad and needs to be replaced.
If it only prints some of the leads but it does print the full report it is because you have the leads mixed up (Wrong spot on the patient) or the leads are mislabeled or some of the clips or electrodes are bad.
I can fix these. Let me know if you need help.
Apr 05, 2009 | Schiller Welch Allyn Cardiovit At 2...
Selectric II return problem
this one is hard to diagnose without actually seeing it, however if it is hanging up on that slider, you can simply remove the slider without any harm to your machine. the slider is a throwback to when "ditto" machines were used for printing. all it does is stop the ribbon from working when it is in the "S" position, and you can do the same thing by removing the ribbon. to remove it, move it to the left and pull till it comes out. if the spring that is attached doesn't come out with it, just pull it out.
however, if the carries goes past the margin all the way to the left of the machine, then this is not going to stop that. what usually causes that is a little lug that faces the carrier on the l. h. margin set lever, if there is a crack in it, it will need to be replaced. also check that when you hit the "mar rel" button the margin rack pivots up then back when you release it. if the rack is stuck in the up position, then that is your problem.
Nov 14, 2008 | Office Equipment & Supplies
Printing Online
i had the same problem, got this solution from brother and it worked!
unplug the fax machine
press and hold the stop button
while still hold down the stop button, plug the machine in
continue to hold down the stop button for 5 seconds
Feb 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
