Question about Compaq Presario X1000 Notebook
I REPLACED MY HARDDRIVE ON COMPAQ PRESARIO X1370US NOWWHEN I TURN IT ON IT SAYS POWER-ON PASSWORD CAN SOME BODY HELP IDO NOT KNOW HOW TO GET INTO BIOS
  • Carlos Trevino Mar 16, 2011
    OK I"M IN BIOS NEXT STEP TO SETUP WINDOWS I"M A BEGINNER HELP ME YOU KNOW YOUR COMPUTERS
  • 2,632 Answers
Welcome to Fixya. If the computer you are servicing has an unknown password, you need to clear the CMOS by removing the battery
Open the Machine
Remove the real-time clock (RTC) battery (CMOS Battery)
Wait approximately 5 minutes.
Replace the RTC battery and reassemble the computer.
Connect AC power to the computer. Do not reinsert any batteries at this time.
Turn on the computer.
All passwords and CMOS settings have been cleared.
If you have questions please let me know. Thanks for using Fixyamoz-screenshot-4.png
Posted on Mar 15, 2011
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
Apr 28, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
I REPLACE MY HARDDRIVE KNOW WHEN I TURN IT ON IT SAYS POWER -ON PASSWORD HELPPP
Go into the bios settings and set your new HD to the first to boot up. boot priority or something like that. it's maybe **** up. I had this problem a couple of times, just play around with the HDD priorities. it will be fine, you can't break anything.
Mar 02, 2011 | Compaq Presario X1000 Notebook
I need bios password for compaq nx9010 plese help
y this procedure. It very serious problem. For someones...
To remove that password there are few steeps:
0. remove AC power
1. remove system battery (primary and multibay if present)
2. remove harddrive from harddrive bay
3. remove Multibay Devices from multibay
4. remove small round battery pill 3.3V, located under a cover on left side of touchpad. Remove cover gently (is no need to remove keyboard, but cover is removable with some power...) Delicate unplug small conector with cables leading to battery,
5. wait 5 minutes
6. connect AC power
7. Turn on computer unit (BIOS gets a few errors = date, time, mismatch etc. no need to panic, if everything is ok then get into computer setup pressing F10, change existing setup values as needed, if ok power down computer.
8. unplug AC power
9. Plug small battery into motherboard
10. install Hdd and multibay devices
11. Install system batteries
12. Power Up computer, there could be no password anymore
Jul 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
How do I reset the power on password on my Compaq presario C300?
1.Reinstall the whole thing...
2. Enter the Bios and attempt to reset. (Unlikely)
Jan 13, 2010 | Compaq Presario Notebook
Ctrl+Alt+Del to restart error
Is it a black screen right when you boot your computer? If so this could be a fatal disk error and the harddrive has crashed.
There is no easy fix other than to replace the harddrive.
Oct 05, 2009 | Compaq Presario 700 470024-192 Notebook
I turn on my compaq presario c300 and it immediately take me to an enter power-on password screen
A password on boot is not set by default. The owner activates this option. If some prankster or michief maker has entered a password on boot on your computer without your knowing it, there is nothing you can do, save taking the machine to an HP Certified Service Center to have the password removed or reset.
As the password on boot is a deterrent against computer thefts, you might be asked to show proof of ownership. This certainly is the case with Toshiba laptops.
Hope it helps.
Aug 30, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq Presario F700
IT CAN BE FIXED.. HANDS ON IS THE BEST WAY . LETS GIVE THIS A SHOT. COMPAQ NOT GOING TO HELP YOU THEY WANT YOU TO BUY ANEW ONE IF IT WORK WHEN IT HAD VISTA , IT WILL WORK NOW, I AM SURE OF THAT. YOU MIGHT HAVE TO HAVE IT COMPLETELY TAKEN APART AND RESET IT , BUT THATS ANOTER STORY , FOR now remove the battery and remove the ram/ memory card, then remove the hard drive , a sigle screw should remove the hardrive memory as well then i want you to hold down the power button for about 3 minutes , then insert harddrive only press power, if you hear a beep good sign if th power button remains after the harddrive is installed, hold power button till computer turns off then install ram memory USE YOUR POWER CORD THREW OUT THIS PROCESS freddiemccly@yahoo.com your computer can be fixed i know its easy said then done ITS MINOR but a tech will tell you the total opposite
Jun 02, 2009 | Compaq Presario 700 470024-192 Notebook
Laptop harddrive
see if you want the data from this harddrive what you can do is bue external harddrive casing and remove the harddisk from laptop and install in the casing and take the backup.
Nov 30, 2007 | HP Compaq Presario 1700T Notebook
Dvd drive
Posdsib;y you will know when you have fitted it.
May 17, 2007 | Compaq Presario X1370US (DZ300U) (DZ300U)...
Compaq Presario X1000 Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
