Question about Garden
I sent repair the diesel pump to experts "Rotto Diesel" for my John Deere 450 B Crawler. When I mount it, I look blank smoke and piston sounds. Also, I look leak diesel from the line that supply diesel from the pump. The injectors are in good condition, it where verify with the personnel of "Rotto Diesel" and it working mint. Have any detail explain or diagram for mount it correctly?
  • 4,348 Answers
Well, fix the leak, but it sounds like the injector pump may not be timed correctly. This timing is critical and the unit will run poorly if out just slightly. Connect with the guys at Rotto Diesel and get directions on how to time the pump.
Posted on Mar 15, 2011
I would like to know the year and the type of fuel it takes gas or diesel fuel 450 C John Deere ser # 2810741T
diesel engine ,219 cu" (3.6L) turbo charged made by john deer
crawler loaders were made in 1965
Jun 23, 2017 | John Deere Garden
What year and model B or C ?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 12, 2016 | John Deere Garden
John deere 415 diesel fuel flow
If its a diesel, the fuel pump where the steel lines come down from top engine. Follow fuel line coming coming from tank to find filters.
Jan 16, 2014 | John Deere Garden
What would cause diesel in oil on a 1070 john deer
If the injector pump is driven from inside the crank case the pump could be the cause of fuel in oil. I saw this problem happen on a Ford
Sep 30, 2013 | John Deere 670 770 870 970 1070 Compact...
Starts good runs good on idol, but under load misses
Is it a lp,gas are diesel?...If lp are gas check timing and point are in some cases the flapper in the carberator.If Diesel it possible the flex ring is coming apart in the injection pump and stoping up the return lines at the injectors retarding the timing advance in the injector pump..very common in the 3020 4010 4020 4320 and 5020 John Deere ag tractors...
May 16, 2010 | John Deere 3010,3020 Tractor Basic...
2010 DIESEL, DIESEL FUEL GOES INTO CRANKCASE, A LOT! TRACTOR CAN NOT BE USED, CRANKCASE FILLS WITH FUEL AND SPRAY FROM CRANKCASE BREATHER SYSTEM. 1963, ITHINK.
do you have an injector pump mounted to the engine block? on some the seals on the pump leak letting the fuel go into the engine. only other thing would be the standpipe maybe cracked or broken. it is probally the pump though.not seeing how it's mounted i cant help much more than this.
Jul 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
2003 tdi automatic, smokes black on every start
Unless you want to scorch the nozzles and risk burning a hole in a piston, do NOT use John Deere conditioner in a TDI. The injection pressures/nozzles are not tolerant of John Deere conditioner. smoke = bad.....high egts....and high egts = melting valves.  Smoke means soot, soot clogs the intake manifold and the vanes in the VNT, And soot from the EGR system. And once that soot is in there, it can harden to what you swear is something melded with your intake manifold's metal. Black smoke on a diesel is power you can see but not use, and the amount of over fueling required to produce it can have disastrous effects on the life expectancy of your engine. Melted or holed pistons, coked up injector tips, coked up rings, stuck vanes in the VNT turbo, all problems that can arise from a TDI that's constantly and consistently over fueled past the smoke limit. Leaving it in 2nd gear will have the turbo revving at a high rate and waring it out prematurely and can cause damage to the Vanes in the VNT for constant over boosting due to high revs. Good luck and i'ld look for a different mechanic who under stands Modern Diesel Racine Design Engines.
Jul 01, 2009 | 2003 Volkswagen Jetta TDI
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
