Question about HP LaserJet 3030 All-In-One Printer
Paper comes out creased most of the time but not always. Could it be the toner or paper? We bought cheap paper last time.
  • HP Master
  • 4,350 Answers
Not very likely that the toner is causing this issue, try quality paper and see if the condition continues.
Posted on Mar 15, 2011
Testimonial: "Thank you!"
  • Sunil Sonavane Jul 18, 2011
    If the toner leaks, it will deposit on the fuser roller/ film leading to improper (non-linear) movement of paper which causes creasing. Remove the black deposits from fuser roller/ film. Creasing problem will be solved. Creasing can also occur due to trapped paper fragments ( due to wrong way of paper removal leading to torn paper). Always use minimum 70gsm paper of best quality with low moisture.
    -sonsunny
How do I fix creases in the paper being printed
Sounds like your fuser needs some maintenance. These are wear and tear machines.
If you're in Houston we can get you fixed up. Skelton is the best copier service company in Houston. Skelton Business Equipment Houston Copiers
Jul 14, 2014 | Sharp Office Equipment & Supplies
When I use card stock on my Xerox 6180 printer the toner doesn't always stick to the paper
1 You need to make sure the weight of the media is within the limits set by the manufacturer. You can probably get away with a bit heavier, but not much heavier.
2 You need to make sure that you choose the correct media/paper type in the printer driver. The thicker the media, the longer it takes for the heat to 'soak' through to the toner side. choosing the correct media type slows the transport through the fuser (or increases the temperature - depending on the printer type - so that correct fusing can take place.
3 Excessive moisture content can cause fusing issues like this.
4 Remanufactured, or 'compatible' toner cartridges that have the WRONG or poor quality toner powder also cause fusing problems that can even bee seen on 80gsm paper, but will be obvious on thicker media. There ARE good remanufactured toner cartridges, but if a toner cartridge is very cheap, it ;s LIKELY to have poor toner powder in it (the correct toner powders are 2-3 times more expensive than the cheap stuff).
5 Finally it IS always possible that the fuser just isn't getting up to temperature properly. This can be caused by a failed heat lamp - with age the can blacken in patches, 'holding back' the heat.
Apr 25, 2014 | Xerox Phaser 3600DN Laser Printer
Creased paper
If that happened to me I'd try printing a dozen - 100, if needed - pure blank white pages in an effort to clear any other problem without wasting toner.
Nov 05, 2017 | Samsung Office Equipment & Supplies
Creased paper
Check the Fuser (rubber roller usualyl a pain to get too with out tools) for caked toner. You will more than likely have to get the printer serviced if it was badly contaminated with toner.
Oct 03, 2012 | Samsung Office Equipment & Supplies
Canon GP 225, When using the photocopier function on this machine the copies are coming out with a crease on them, almost even a fold in the paper, the machine is not jamming however and the paper comes...
This crease is most likely caused by the paper buckling just before it enters the fusing unit. The fuser is the part that gets hot just before the paper exits the machine. I would check the "ramp" that guides the paper into the fuser. They sometimes get toner build up that the paper catches on. If the paper does not go straight and flat into the fuser you will get a very tight crease or z-fold in the paper due to the heat and pressure applied to the paper to fix or "fuse" the toner onto the paper.
Dec 23, 2009 | Office Equipment & Supplies
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
Black smudge marks on our prints.
If you are using a generic brand of toner, this could be the problem, and if so, your developer is shot, and the drum unit will need a thorough service.
Otherwise, it is very likely that the Drum (PCU) needs replacing, or fuser is failing.
Whatever the cause, it requires a technician.
Mar 12, 2009 | Ricoh Aficio 450 Copier
Appears to be a roller crease on the paper
i want the installation cd fo my printer HP PSC 1410
Jan 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 3030 All-In-One Printer Logo
180 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
