Question about Samsung SyncMaster 920LM 19" LCD Monitor
The top part (about one third) of my SyncMaster 920LM screen is brighter than the rest and seems to retain simultaneously the new and the previous picture for 2 to 3 seconds before it gradually fades out into the new picture. For example I am in my internet browser and press exit to go into the windows starting screen, the computer (and screen of course) goes into the starting screen but the top third of the screen shows simultaneously the new picture but also faintly the corresponding top part of the previous browser screen - this is only for a second or two. Can you help?
    Scholar:
  • 88 Answers
This is usually do to a section of your controller chips dying. This is not fixable by the end user, the only thing I could say to try is to try different resolutions to see if you can reduce the issue.
Posted on Mar 15, 2011
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
Samsung syncmaster 920lm wont stop going off and on
For this case, you need to open lcd case and try to find power inverter board. That cause by cold soldering joint and you need to check and resolder all them.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
I have a Samsung SyncMaster 940B monitor. When monitor is turned on, it dimly displays the screen graphics, then quiockly dimd to black. this happens each time the power is turned off/on. The caps in the...
Souds like you need in-depth troubleshooting. Voltages checking that will be next, caps have completely flat tops, bad cap can look normal but can have high ESR.
One of these should match your chassis, Service manuals: http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=940&kategoria=monitor&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 12, 2011 | Samsung SyncMaster 920LM 19" LCD Monitor
When i turn onmt Samsung SyncMaster 920LM 19 inch LCD Monitor it blinks on the left upper corner for a few moments
WQhen you get strange problem like this, first place to look will be the caps in the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 14, 2010 | Samsung SyncMaster 920LM 19" LCD Monitor
Monitor Blank screen,
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 02, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Sound problem
On you screen there are button, which you can change settings on your screen itself , go to the volume control, and just set your volume on your screen higher, note: not on your pc, but on your screen itself.. enjoy the sound
May 25, 2009 | Computers & Internet
No sound on my Samsung Syncmaster 920lm Monitor
This seems to be easy.
1) Your monitor will need to be connected to the sound output using a separate cable, unless it uses HDMI cabling.
2) If that doesn't help, check the sound output using headphones or a different speaker system.
Check it out and post your response here.
Oct 09, 2008 | Computers & Internet
2 inches of picture from top is brighter and picture in tthat area is distorted
Hmmm, could be anything from dirty optics, to a convergence problem....accordianman
Nov 04, 2007 | Hitachi 50UX57B 50" Rear Projection...
Samsung SyncMaster 920LM  19" LCD Monitor Logo
88 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
