Question about Frigidaire Dryers
My model #LG01442ES2 is not heating up. It is a gas dryer and we have checked everything.It also shuts off in a 10 min time frame when on a setting such as NORMAL but runs thru the timed settings.
  • 156 Answers
SOURCE: Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Posted on Mar 19, 2008
ngfam1
  • 639 Answers
SOURCE: Roper gas dryer not heating
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
CHECK THE LINT FILTER IS CLEAN AND CLEAN IT AFTER EVERY LOAD1
BUT IF THE VENT THAT LEADS OUTSIDE IS CLOGGED IT MAY CAUSE THIS .
IN THE OUTSIDE OF THE HOUSE THERE IS USUALLY A SCREEN AT THE VENT POINT THAT STOPS ANIMALS FROM ENTERING THIS VENT. GO LOOK AND CHECK THAT IT'S CLEAR AND FREE OF WADES OF LINT THAT MAY BE BLOCKING THE AIR OUT FLOW.
THIS WOULD STOP IT FORM DRYING AND GETTING HOT ENOUGH TO DO THE JOB! IF THERE IS A DOOR THAT FLAPS OPEN OUT SIDE AT THIS SAME LOCATION WHEN THE DRYER GOES ON, CHECK THAT IT IS HANGING LOOSELY AND NOT STUCK CLOSED!
OTHERWISE YOU WILL NEED SERVICE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business! they answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE: kenmore gas dryer after 5 to 10 min. later no more heat
Yup, shortly after I posted this question I was able to find that it was indeed the valve coils. Very easy to get to and replace. Cheap too! Got both of them for about $20 thru www.appliancepartspros.com. Same parts would have cost about $70 thru Sears direct.
Patrick, they are located on the burner unit under the drum in the front left. You can get a diagram of the burner unit by looking up Parts for your model # at Sears.com.
Only tricky thing is you may need to have someone help hold the tumbler in place when you put the belt back on the motor. Personally I found it easier to use two hands to manipulate the belt around the motor and tension bracket and have my wife hold the drum in place rather than to try and balance it myself.
Posted on Oct 27, 2008
  • 1214 Answers
SOURCE: Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
Y wonnt the flame shut off
Model #? Problem is not clear. May be blocked airflow from filter trap all the way thru the 4" duct outside the back of the dryer OR may be faulty gas valve that doesn't completely close when "OFF."
Oct 16, 2014 | Dryers
The dryer will run fine with no heat but when you try to dry with heat, whether its high or low, it runs for about 5-10 mins, with out getting warm and then shuts off and all the lights flash on it
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Kenmore 84152 Electric Dryer
My dryer only lights the first time.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | GE DVLR223 Dryers
No heat from dryer
i believe a while back, this model had a timer issue, but would need exact model to be sure,
anyway its a pretty asy repair and the part is easily available at
the average timer is around 80
and about ten minutes repair
Oct 15, 2009 | Kenmore 73952 Gas Dryer
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Jan 09, 2009 | Kenmore 62802 Electric Dryer
I HAVE A AMANA DRYER MODEL # LE8217W2 THEY DRYER WILL TRY TO START AND TURN OVER LIKE A COUPLE OF TIMES AND WILL HEAT BUT SHUTS RIGHT BACK OFF--BELT IS FINE ELEMENTS HEATS? WHAT WOULD BE NEXT TO CHECK?
sounds as if the motor is overheating, shutting off and not restarting for 10-20 min??? if thats the casse sounds as if yooull need a new motor assemly
Dec 03, 2008 | Amana NDE2330AY Electric Dryer
Whirlpool gas dryer
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Sep 06, 2008 | Whirlpool Dryers
Dryers Logo
54 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
