Question about Cameras
I put brand new batteries in my camera, after it died, and now it will turn on and say empty battery. I have no idea what is wrong with it..please help!
  • 477 Answers
This error can because by several different things the most common is a defective flash circuit causing the compositor to never charge which will drain the battery. If I can help any further contact me @ www.digitalcamrepair.com
Posted on Aug 01, 2008
Empty batteries
Your camera may have been in wet conditions. So "short cut" may have been occurerd. Please firstly put your camera in a hot and dry room. Wait at least one day. After that process. Try again to use with brand new batteries. It will work I think.
Feb 22, 2010 | Olympus FE-210 Digital Camera
Lumix dmc-fs5 digital camera not turning on without charger.
Some Panasonic cameras only work with Panasonic batteries...part of Panasonic's plan to dominate the world! Is your replacement battery an off-brand?
Feb 19, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
My camera dies way too fast
If you use a lot of batteries, it is a good idea to have a battery meter (tester). Radio shack has one for about $5. I say this because I've seen a lot of "brand new" batteries that aren't any good, especially imports. AA, AAA, C,D batteries should all read at least 1.5 volts dc. Under test, if the battery voltage drops slowly, it is bad. A very good battery will actually show a slight increase in voltage under load. Make sure the polarity (+,-) of the batteries installed is correct.
If you are sure you have the correct memory card and it still doesn't stay in, it could be that the retainer tab is broken. If this is the case, try inserting a small piece of paper as a shim, and that may hold it in place.
If the camera is under warranty, you may want to return it.
I hope this helps.
Nov 25, 2008 | Samsung S860 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Put new batteries in doesn't work
I keep getting the same problem myself with particular brands of batteries, if even they are brand new.
Try using Duracell or another brand of batteries and this hopefully, should resolve the issue.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 01, 2008 | Olympus FE-210 Digital Camera
Brand new pentax E35
EINAI SKETH MALAKIA H PSIFIAKI
Jan 31, 2008 | Pentax Optio T20 Digital Camera
Digital camera
Take batteries out and clean the base of the battery compartment with a pencil eraser do the same with the battery compartment cover contact's now try. If that fail hold the battery compartment tight then turn on. If it comes on then - open the compartment and lay a piece of foil across the batteries and close the lid. does it work? No to bad it dies but you should have a warranty- do you have other proof of purchase?
May 22, 2007 | Sanyo C5 Digital Camera
Please help
It should still be under warranty, sounds like the rechargeable battery has died, either take it back to the shop or buy a new battery.
May 03, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
241 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
