Question about Uniden Cordless Phone
Disconnect and static
We thought the trouble WAS the phone so my dad went out and bought a new cordless phone. (It is a good phone, can't remember the name...) Still we have the problem of static on the line (his line!) and for no apparent reason, the phone will just disconnect. My dad does not have a computer. He does have an alarm system (ADT) which he has had for years. Why is this happening all of a sudden? The phone company has been out twice and have done nothing to fix this problem. They are saying it is the fault of ADT- something isn't quite right with it...The phone company has checked the outside lines and supposedly the inside lines. Any ideas?????
Turns out the old ADT alarm system, which had shown "fault" for over a year on the wall box might have seized the line . My husband replaced the battery in the motion detector (which was the particular fault that was showing) and so far things seem to be ok. If this doesn't work, my husband is going to rewire the phone in my Dad's house. I was impressed with the quickness of a response to my question by kaylynnie. She did a great job even though the jury is still out on if this actually completely did the trick. Thanks!
Posted on Aug 04, 2008
    Problem Solver:
  • 15 Answers
Hi mgee 7890,
The main thing you stated that makes me feel the issue is with a line. Maybe not ADT. Security systems sit idle until needed. However, if it is an older system and has a failure, it could seize the line and disconnect. But with the static issue, it does sound like an inside wiring issue. There may be a short in the connection to the alarm system. I would call an independent wiring person. They are cheaper and can test from end to end. When two companies like this are involved sometimes finger pointing slows getting a resolution. So this takes care of that. Also, if there is a short they will usually reconnect it so you know you have a good connection. If this helped, please rate my response. And feel free to respond if you have any additional questions.
Kay
Jackson Communications
Posted on Aug 02, 2008
Phone has bad static on it. Bought a new one and now the new one has static as well.
This is a line issue. Not the phone. The best way for you to trouble shoot is to disconnect all lined from the hub except the one that you are testing. Make sure you are grounded as well at the hub. If you get down to one line and you are grounded then you need to run another new line and get rid of the old line.
Feb 18, 2016 | Panasonic KX-DT346-B Digital Phone, Keypad...
What is going on with my brake lights?
did he clean the fuse box contacts
Mar 01, 2015 | 2001 Jeep Grand Cherokee
Router caused cordless phones to be useless?
You need to replace the router.Try using the same brand.If you have the same problem try another brand.I had the same problem changed brands problem went away.
Good Luck
Mar 21, 2010 | D-Link DIR-825 Wireless QuadBand Router
Phone line goes to fax
Lightening is definitely a factor. When you say it defaults to fax, do you mean that the fax machine picks up as soon as the phone rings? Most likely the fax software/machine has taken a hit. One way to check is to try it on another phone line, preferably at another location. So the cordless phones work all right? The static is probably something the phone company will have to fix. They have lightening arresters that will develop those conditions. Again, try a known good phone on the line. Preferably disconnect all the phones at the junction box where the phone line comes in and plug a known good phone into the jack. If you still get static, then the phone company should get involved. Otherwise you could have a problem with the house wiring.
Jun 19, 2009 | HP Photosmart 2610 All-In-One InkJet...
After a storm and the power went out, but don't think I was hit
Cordless phones are notorious for taking a hit from lightning storms. Your main base is more than likely the trouble. This leaves the remainer of the phone system ophans, unless you can find the same model of base system to replace it. The only testing you can do is unplug the every other phone in the home, and only leave the main base plugged in lto see if the line clears...it just may be one of the other, with a little luck. You may also want to try just plugging in a single corded phone to verify that line coming into home is good also.
Apr 16, 2009 | Uniden 2.4 GHz Cordless Phone System
Static interference on Uniden 5.8Ghz phone
i have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
Apr 13, 2009 | Uniden 5.8GHz Dual Cordless Phone
GE digital 6.0 cordless phone with 411 google
first : go through settin up your phone with the manual( as much as im directing to manuals that much im staying out of my own way ) :) succes
Oct 20, 2008 | Uniden Cordless Phone
Static electricity
I had the same problem when I answered my cordless phone static charge went thru me and into my phone and I had now display, so i changed the batteries in the handset and it worked. So I hope this works for you.
Feb 29, 2008 | Uniden DCT646-2 Cordless Phone
GE cordless phone 2.4 ghz
Your phone must be away from other appliances (i.e. microwaves, radios) and computer equipment (i.e. wireless routers, monitors). The phone runs on 2.4GHz which often conflicts with them.
Mar 15, 2007 | GE 21009GE3 for 21028GE3, 21028GE3,...
Uniden Cordless Phone Logo
357 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
