Question about Nintendo Wii Console
Wii fit tryed to plug in wii fit and install remotes fully charged as they are showing 4 lights flashing but remote wont connect and let me procced please help
  • 659 Answers
Are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Posted on Aug 01, 2008
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
I have purchased a new Dr Who sonic Screwdriver wii controller, unfortunately the instructions were thrown out with the packaging and i am having trouble charging it. I have it currently connected via usb...
Hi, Here is the relevant text as found in the instructions:"Plug the mini USB end of the supplied USB charge cable to the charge socket on the Sonic Screwdriver Remote Controller (SSRC) and other end [ their error, not mine -KP ] of the charge cable to the Wii console. A red LED charge indicator is on when charging. When the battery is fully charged, the red LED automatically turns off. Charge time is between 2 to 3 hours and a fully charged battery has between 6 to 12 hours of playtime.""The Wii Console must be ON for the SSRC to be able to recharge its battery. It will not recharge when the Wii Console is OFF or in Stand-by Mode."" Charging : LED lights up"" Full charge : LED goes out"Hope this works for you. Keith Pyne
Jan 29, 2011 | Computers & Internet
Wii remote wont connect ?
if it wont sync after using the red buttons then its just bad batteries from the sound of it or the remote has gone bad.
Try fresh batteries or let the rechargeables charge (assuming they arent bad)
Apr 30, 2010 | Nintendo Wii Console
Wii remote
Try to resync your remote. To do this:
1) Locate the red button under the battery cover on your remote.
2) Locate the red button near the sd card port on your console.
3) Press both buttons within a couple seconds of each other.
4) Wait a few seconds if your remote doesn't sync, retry.
Good luck. Please rate, thanks.
Mar 03, 2010 | Nintendo Wii Remote Controller
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
My nontendo wii controler does not seen to charge up and the batterys come as fully charged on my battery charger. When i press the power button it flashes then turns of again. I had my controller on the...
did you do the whole thing where you have to hold in the button to assing the controller ? if not look in the manual it will tell you how to do it in there i do not know how off hand
if you do not have the manual let me know ill look in mine and let you know how to do it
Jul 14, 2008 | Computers & Internet
My wii remote wont work
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jun 21, 2008 | Nintendo Wii Console
HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Mar 28, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
220 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
