Question about Nortel Networks T7406 900 MHz Cordless Phone
Change long ring to short ring - Nortel Networks T7406 900 MHz Cordless Phone
How to extend ring time before answer machine cuts inExtend ring time
you're gonna need to go to your menu options to change the number of rings. Google your model and then look under manual. Perhaps this is it: http://www.home-phones.co.uk/assets/uploaded/documents/384_BT_Synergy_5500_userguide.pdf
Nov 04, 2014 | British Telecom Synergy 5500 Trio 4Line...
Long distance not ringing in
go into the programming and change the ringer for inbound calls.
You have changed the default to a custom setting.
Dec 09, 2013 | Uniden DECT 6.0 Cordless Phone ID
My phone only rings 3 times before going to voice mail. i want it to ring 6 times. how do i change it?
Since you don't say what phone, what OS, or what carrier, I can only provide generalities. In the setup menu, look for the ringer or ring tone section. There's usually a setting for long or short, or something similar.
Jul 07, 2011 | Computers & Internet
Short ring tone
You can change the ringing type from "ring once" to "ringing". (Settings>>Profiles>>General>>Ringing Type)
or
you can choose a ringing tone with a longer duration.
Mar 10, 2010 | Nokia 6120
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
Phone numbers
Try changing the advanced fax setting rings to the same style of rings as distinctive ring-All, two shorts, two longs etc.
Apr 29, 2009 | Vtech 5.8GHz Analog Cordless Phone
LG KF310 ring time too short
change the ring tone some ringtones are short especially the ones that come stock on the phone
Apr 03, 2009 | LG KF310 Cellular Phone
How do i gwet the hp officejet pro 7680 to get two short rings
To change the answer ring pattern for distinctive ring via the control panel 1 Verify that the device is set to answer fax calls automatically. 2 Press Setup. 3 Press Advance Fax Setup, and then press Distinctive Ring. 4 Press the right arrow button to select an option, and then press OK. When the phone rings with the ring pattern assigned to your fax line, the device answers the call and receives the fax
Mar 13, 2008 | Office Equipment & Supplies
Audible ring has changed/machine won't answer when called
It is to do with "smart ring" feature or in your area called "distinctive ring" feature. The machine won't receive unless the ring pattern matches your distinctive ring pattern. If you are not using that feature, then you must turn the feature off. Then set your receive mode to "fax tel" mode if it is your only line.
Jan 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Nortel Networks T7406 900 MHz Cordless Phone Logo
20 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
