Question about Sony CPU FAN CPU Fan
Sony TZ240n problem.
Hi ! U gotta problem with my Sony Vaio VGN-TZ240n cooling system. Fan works hard(i can guess becouse of the noise it makes) but it doesnt effect. THE CPU temperature gets to about 65 celsius (measured by "speedfan") . The Notebook is brand new and my question is- is it normal? How can I make it run more silent and to become cooler at the same time.
Jacob.
    Genius:
  • 1,027 Answers
If less than 90 days, it is under Sony's full coverage. Usually the fan runs intermitantly. Check that air paths are not restricted.
Posted on Aug 02, 2008
I have a sony vaio VGN-TZ240N. every time I hit the "A" key I get "AS". I have removed the key and cleaned the inside with isopropilic alcohol, but the problem remains. Any help you...
It could be a problem with an electronic trace on the keyboard or the integrated chip. You might have to get a new keyboard.
Have you also removed the S key and cleaned that area?
Mar 21, 2011 | Sony VAIO VGN-TZ240N/B 11.1" Laptop
My laptop (sony vaio VGN-CS325J) fan makes a horrible noise
Hi kufreudokang,
The VGN-CS1xx, VGN-CS2xx, VGN-CS3xx computer models have a known issue that the cooling fan in the Computer may make continuous scraping, whirring, chriping and/or clicking noise while running. As a part of Sony's commitment to quality, Sony provides a free repair for an additional 36 months beyond the standard limited 12 month warranty (48 months total) for fan replacement.
As you're experiencing the issue, you can contact Sony Support at 1-888-476-6972 to set up a repair service at our Sony repair facility.
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 11, 2010 | Sony VAIO VGN-SZ330P/B Notebook
May laptop make noise.
It Is Mostly due to a cooling problem or over working problem, for cooling you should check your fan if it is working correctly, also try to work using your laptop in a cooler place (Thats good for its parts), for over working problem, try not to open it more than 4 continuous hours.
Jan 31, 2010 | Sony VAIO VGN-FW390JFB Notebook
My vaio VGN-FW390 fan make noise.
The fan makes noise in high preformance windows like windows vista&7. So it is normal, because the windows uses motherboard,ram and graphics card with high preformance so they get hotter, so the fan get stronger to cool them or they will be damaged.
This noise also exist in windows xp, but only when opening high graphics game, or being working with the laptop for along time.
My vaio vgn-cs320j makes a loud spinning noise that comes and goes every few seconds or minutes. Is it the fan not working properly or some other issue, or is that just what the fan sounds like? if it is...
Usually Sound from Notebook are from CPU cooling fan and from Hard drive.
But It's hardly occur in the case of Hard drive.we called it Hard drive failure and the only solution for this is new replacement.
Your problem could be CPU cooling fan not working properly. Open the Notebook ( it will be easy if you refer to manual on how to open) and start the system now, you will be able to pinpoint what causes the sound.
Clean the CPU cooling fan with an air blower and re-check if the problem still persists.
If OK,then close the Notebook otherwise replace the CPU Cooling fan with a new one.
Jan 13, 2010 | Sony VAIO VGN-CS320J Notebook
Sony vaio fan is making a grinding noise, how can i fix this?
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
Nov 15, 2009 | Sony VAIO VGN-S460 Notebook
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Oct 15, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Turns off automatically
check your cooling fan sounds like its getting too hot
Oct 03, 2009 | Sony VAIO VGN-CS220J/W Notebook
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
Computers & Internet Logo
282 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
