Hi,my techwood flat screen tv needs retuning and i have no instruction booklet,any help with this please
4 Suggested Answers
  • 34 Answers
SOURCE: won't switch on
What brand TV is this? Sounds like the power board may be out. You could check for power at the power board with a Multimeter. You need to have power run to the TV but TV not powered on. Board usually has a led green or red light to indicate power to the board. Sometimes this light can be seen without taking the cover off, sometimes you may have to remove cover to see power board and definitely to test with multimeter. Hope this helps. J
Posted on Apr 08, 2009
SOURCE: I have an Apro TV, AL-1540T. I am having trouble
I have an Apro TV, AL-2010ht I am having trouble retuning freeview , I cannot find the instruction booklet so please can you offer any advice?
Posted on Nov 05, 2010
  • 11800 Answers
SOURCE: I have a 40in polaroid flat screen and I can't
The cause depends on how you use the tv and what are its connections.
If you are using a box of any kind then the defect is in the the connection: either the cable connecting the tv to the box is damaged and it will have to be replaced or the selected input in the tv's menu isn't the one actually used - this happens when you use a Composite or S-video connection and you have selected as input the Component or the RGB connection. In that case just select the correct one. Of course i've assumed that you have correctly plugged the cable.
If you are using the tv directly from an antenna or the cable then the problem is in the tv system used: it should be NTSC or automatic and it's set on PAL. Depending on the exact model of your tv this setting can be found in either the Setup section (usually under the Country or System options) or in the Video. To fix it you will need to go into the Menu, find it and set it correctly.
Posted on Jul 15, 2011
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Techwood TV 37I asked for a set instructions to be sent by download was wondering how long does it thank you
Hello Graham
usually it depends if someone wants to pick up your request, or in some cases they try, can't find anything and move onto another question, in the hope that someone else can help you.
I am one of the manual or instructions experts, but in reality, I am just good with search engines. From a quick search, I reckon that you are not actually giving a full model number. That looks like '37-one', but Bing reckons it should be 37-letter I. However looking at the other Techwood model numbers they are much longer. Look at this;
TECHWOOD LD3711 37" LCD
Seems they are actually made by Matsui and badged Techwood?
This maybe that your television shows 'Techwood 37i' on the front, but the full model number is on the rear near the mains cable. It will also have a serial number but we don't need that.
All you have to do is Google
make model manual
or
make model instructions
The top site on the link below 'manualslib' is the best one. Stay away from any that ask you to download anything, or any that show a link in a PDF file. The don't have you manual and are just 'clickbait'.
http://www.bing.com/search?q=techwood+tv+37i+manual&qs=HS&pq=techwood+tv+37i+manual&sc=1-22&sp=1&cvid=1EB6D9B22E49423FA93DF3199F715E92&FORM=QBRE
Post back as a COMMENT if you need any further help, and please don't start a new post to reply to a question.
Andrew
Fixya moderator
Jul 01, 2016 | Televison & Video
How to retune tv programmes tv telling me to retune but i cannot access instructions on tv?
Depending on the TV model, if you do not have the instructions for the TV/remote, you may just have to play around with the options via the remote and find the choice for retuning the stations.
Sep 18, 2014 | Televison & Video
Matsui helpline
Just go to your TV settings and just do a full reinstall ,like the day you brought your TV ,below is from the web site your tv will work hope this will help.
The Freeview TV guide is being updated on Wednesday, 3 September 2014 to create extra capacity for new services. As a result, Children's and News channels will move to new channel numbers.
• The Children's genre will move from channel numbers in the 70s to start at 120
• The News genre will move from channel numbers in the 80s to start at 130
To update their guide viewers simply need to retune their Freeview TVs and digital recorders or boxes where equipment does not pick up the changes automatically. On-screen messages will prompt viewers to retune late afternoon 3 September 2014 onwards.
Viewers who don't retune will not lose channels - services will remain accessible at their old numbers. However, Digital UK and Freeview recommend viewers retune from time-to-time to ensure they have access to all available services in their area.
Aug 29, 2014 | Televison & Video
User manual for techwood dvd 22875
my techwood 22875 hd dvd has lost colour good pic but no colour on tv and on dvd
Oct 30, 2010 | Televison & Video
Samsung tv will not retune
HI
1 Turn off the TV so its on standby
2 Then press these keys one after another
Info, Menu, Mute, Power.
When the TV turns back on you are in the Service MENU.
Now press your down arrow key until you get to number 12 on the on screen options,
It’s marked RESET.
Push the arrow key to the right, to RESET your TV.
Next simply follow the instructions on the TV to retune your channels.
OR
Press D.Menu on your remote. Select Channel. Auto Store.
That should do too.
Thanks for contacting fixya.com
Dec 03, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
I have an Apro TV, AL-1540T. I am having trouble retuning freeview because all the DTV menu options are being displayed as blank. I cannot find the instruction booklet so please can you offer any advice?
Sep 22, 2009 | Televison & Video
I need a user manual for audio sonic TV Mocel KM 1427 please
need to retune my sonix15"tv model so15 i cant find the booklet
Nov 18, 2008 | Sony Part 996804671 Service Manual for...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
