Question about ViewSonic PJ503D Projector Lamp
My PJ503D shuts down maybe a minute or two after turning it on, what causes this? is this the lamp? anyway, the lamp time usage has already reached 937hours,
  • 138 Answers
Hi mayn,
i have some proposal for you reference,
1-- does it thermal overload protetion?? so check the van is working or not,
2-- check the color wheel is ok or not? clean it and check the 8pin chip loose contact or not?
3-- the last, consider the lamp, but it just worked less than 1000h, it should have longer life,
hope this is helpful for you,
Jacky,
you can freely contact me for further help, by mail, wanmingjun@gmail.com
Posted on Mar 16, 2011
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
How do i reset the lamp hours on viewsonic pj503d i cant afford another bulb right now and i know theres a way to reset it just trying to buy some time untill i can afford one thanks alot
Though you can reset timer in the info menu it is unwise to do so as the bulbs can explode if they go past there usage time and can cause damage to projector.
Have a look on ebay there are a lot of bulbs on there maybe you can find a cheap one.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | ViewSonic PJ503D Projector Lamp
Can you advise what voltage this machine uses ie is it 120 or 240
It sounds as if the machine heater is going down
That comes into circuit as the water level is reached and can develop cracks in the outer shell which leak electricity via the water causing the trips to shut down
You can run your own test by taking the back off the machine removing the connectors from the heater (Tape them up with insulating tape ) and then run the machine.
If the heater is at fault then the trip will not shut down but the machine will not advance because it is waiting for the water to reach the right washing temperature.
If it proves to be the heater they can be replace quite easily.
If that does not stop the trips blowing then you are looking at the main motor.
10 years for a washing machine is not a long life but that depends on the usage it has had the environment it has worked in
Apr 08, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Sony Grand Wega KF-50WE610 turns on and off audio and visual
Lamp maybe the problem they only last 5,000 playing hours Mats has best Price for them
1-800-628-1118 Fisrt CK the Fans If Lamp fan quits working Lamp will shut off to protect Lamp from burning up.
Visit Encompass Parts Distrubtion they will list Parts for this Model.
Mar 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Abs light wont go out
When u power up the vehicle ABS does a self test(light stays on a few seconds then cuts off) and if it see's a problem will shut off and illuminate the ABS lamp. It will also do a second test on iself when you reach a speed of around 12-15 mph,it will run the pump for a few seconds to check pressure and look at the speed sensors,if it see a problem here it will again shut down and illuminate the ABS light.
Now if the red brake lamp is on then it will shut down because it thinks you have a hydraulic concern and will not try and run ABS if this is the case.
If red brake lamp is on most likely if you have good brakes it is a problem with the float sensor in the master cylinder reservior,maybe its bad or just stuck,or just low on fluid.
Feb 12, 2009 | 1992 Ford F250
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute...
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
Jan 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
ViewSonic PJ503D Projector Lamp Logo
253 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
