Question about Roper REX3614KW Electric Dryer
My Roper dryer is a little over a year old. When I turn it on it makes a humming noise but the drum does not turn and then I smell a burning smell. I cam move the drum with my hands and it will turn. Of course it is just out of warranty. Any ideas?
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
Is it worth getting my Beko tumble dryer fixed?
of course only 2 years old it should be .
Mar 12, 2015 | Dryers
My whirlpool cabrio dryer drum won't move making humming noise and smells like something is burning
Pull the back off or the front off the dryer and check for a broken drum drive belt.
Feb 09, 2014 | Dryers
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Aug 04, 2013 | GE Dryers
When I pulled out the lint filter to clean it I heard a metal clinging noise from underneath (it sounded as if a srew fell). After cleaning the filter I put it back and started the dryer and I kept...
Its common for coins left in pockets to dislodge from the clothing. Most times you see them in the drum. On rare occasion they can get into places that could damage dryer. However since there is a burning smell it is not something to guess about. Being that it is less than a year old it should be warrantied, if it is not a mal-funtion you would still want to fix it. Call Lowes and set up a service call
Aug 17, 2011 | Roper REX4634KQ Electric Dryer
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
f you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 18, 2011 | Kenmore Dryers
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Dryer got very hot and smelled burning..
This is usually a result of a stalling idler pulley or drum, causing a burned spot on the drum drive belt.
The situation will only worsen. The belt is best replaced before it breaks.
Items to pay attention to, when the drum drive belt is replaced, are:
(1) Clean and lube the idler pulley and drum roller shafts.
(2) Confirm that the drum glides will yield additional service life.
(3) Check motor condition and de-lint the blower housing and blower intake pathways.
Sep 07, 2009 | Maytag Dryers
Maytag dryer mod #mde600ayw only makes a humming noise when start switch pushed will not turn.
a hum with a burning smell means the motor winding has failed.
you can try this: open the door and hold in the door switch, have another person hold the start button. You manually roate the drum by grabbing a fin and moveit while the unit is humming.IF the dryer starts, you need a motor.
Good Luck!
Feb 28, 2009 | Dryers
Roper REX3614KW Electric Dryer Logo
89 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
