Question about Intel Motherboard
Bios the error of date and time is not ok
    President:
  • 2,351 Answers
Hi, if you're system does not keep the correct date & time it is possible the cmos/bios battery on the motherboard has reached it's max life span. The bios battery recharges only when the system is on. In many cases even when the system is on & you correct the date & time & notice the time is off the battery needs replaced.
bios - 92208a8.jpg How to replace cmos battery:
http://www.computerhope.com/issues/ch000239.htm
Mike
Posted on Aug 01, 2008
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Mar 28, 2014 | Computers & Internet
How do you set the system date and time
To set the Date & Time, go into the BIOS setting - date 7 time.
When you set the Date & Time and you get this error again when you next boot up your computer, then most likely you have a flat BIOS battery.
Then replace this battery, it could be a coin size battery - 3 volt lithium battery type CR2032. and then go into the BIOS setting and set the Date & Time.
Oct 22, 2012 | Gateway Essential 500 PC Desktop
Date problem
When the Date and time error message comes up during booting up the computer, it means the BIOS requires configuration.
If this occurs every time you boot up your computer after changing the Date and Time then, this is caused by a flat BIOS battery.
The BIOS battery is ususlly a 20mm dia. 3 volt lithium battery type CR2030
Replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Computers & Internet
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Ibm thinkpad
The 161 CMOS error means the CMOS/BIOS battery is dead/flat and needs to be replaced.
The 163 CMOS error means the Date and Time could not be updated when you change the Date and Time setting. This is caused by the flat CMOS/BIOS battery.
When you replace the battery with a new one, the BIOS will go back to the default settings, go into to BIOS setting (press F2 when you boot up) and change the Date and Time, then save and exit.
Jul 29, 2009 | IBM Computers & Internet
It says there are error codes 163, 8611, and 163 time and date pop up but if you try and pass that it freezes and shuts down again. please help
The 163 error is a BIOS Date & Time error. Go tinto the BIOS setting and set the Date & Time. If you boot up the next time and you get the same error, this is cause by a flat BIOS battery, replace with a new battery.
The 8611 error relates to the PS2 mouse bus connector, try a new mouse or use a USB mouse.
Jun 14, 2009 | IBM ThinkPad 600X Notebook
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Error showing on boot
The 161 error means the BIOS battery is dead (flat).
The 163 error means the Date and Time is not updating.
The BIOS battery needs replacing and the BIOS settings need to be configured (ie the date & time)
Mar 31, 2009 | IBM ThinkPad 600X Notebook
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
I got a thinkpad 2635 yesterday from a friend and upon powerup it displays an error message with 00161 and 00163 printed under it with two options ok and cancel what do i do to get into this thing
These error message relates to the BIOS and it appears the BIOS battery requires replacing because it is flat.
error 161 usually BIOS has lost its configuration/ checksum error.
error 163 usually BIOS clock not updating.
Replace this battery and go into the BIOS setting and configure the date/time settings, and hardware settings (if you are not sure select the factory default settings) save and exit
Dec 12, 2008 | IBM Thinkpad T20 Notebook
Intel Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
