Question about HP LaserJet M5035 MFP Printer
Have A M5035 MFP Getting a 30.01.34 Scanner Failure Replaced the whole scanner assbly and the formattor with new ones but still getting error dont seem like the scanner is getting any power scanner does not move or light up
  • Anonymous Mar 22, 2014
    I turned it on and it said scanner failure. The scanner button is in the unlocked postion and i have turned it on and off several times
    Genius:
  • 1,089 Answers
The book says to replace the scanner control board 1st.
Problem can also be with the hard drive.
Posted on Mar 16, 2011
  • Tony Diaz
    Tony Diaz Nov 07, 2013
    Check the cable that goes to the back of the scanner down to the formatter board for damage. Parts that you will need to repalce will be the cable Q3726-60101 & the Copy Processor Board Q6005-67901 only if the SCB does not fix the problem.
  • Benjimen Sellers
    Benjimen Sellers Mar 05, 2014
    When you open the top of the scanner on the left side has a lock and unlock switch. Some people may have this locked and not know it. If it is locked just unlock it to free the scanner and restart. Hope this helped
  • 3 Answers
CPB part#: Q6005-67901
Have A M5035 MFP Getting a 30.01.34 Scanner - 5e310276-f103-4e4b-b804-08156ba222e8.jpg
Cable Q3726-60101
Posted on Nov 07, 2013
Initializing scanner
Update the firmware
Restored factory defaults
Initialization of the hard disk.
If it still doesn't work try to clean the scanner head under the glass. Clean the lens with some alcohol but be careful not to scratch the lens.
Mar 12, 2013 | HP LaserJet M5035 MFP Printer
30.01.08 error in 5035 printer
Scanner Optical Unit Position error
ghgqqfurnqede6juma6zdorgcdcrgbungvircurszbwe2qxsm5bmfos7wlq+v8besk4mgeqwciaaaaasuvork5cyii=
The insert above is from the manual.
Run the 'flatbed motor' tests
Oct 18, 2011 | HP LaserJet M5035 MFP Printer
Can i scan to email with m5035
You can, but you need to configure
Sep 05, 2011 | HP® LaserJet M5035 MFP Laser...
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
Jul 12, 2011 | HP LaserJet M5035 MFP Printer
30.18 - scanner failure
This indicates a problem with the scanner control board. You may be able to resolve the problem by updating the firmware on the printer. If not, then you will need to replace the scanner control board PN Q7829-60165.
To update the firmware, download here If you have Windows operating system, choose the last option becuase if is a self running program so you do not need to do any fancy stuff, it does it all itself. Hope the update gets you going.
Jun 01, 2011 | HP LASERJET M5035 MFP All-In-One Printer
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Laser error
You may have to replace the laser/scanner assembly or the DC Controller
Sorry
Jan 17, 2011 | HP LaserJet M5035 MFP Printer
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Jan 22, 2009 | HP LaserJet M5035 MFP Printer
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
HP LaserJet M5035 MFP Printer Logo
4,413 people viewed this question
Seeker5211
Seeker5211
