Question about Samsung Phone PDCSLCD12B
How do you allocate an action to a button on the keypad.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Hi to program your soft keys either follow the instruction or click on the link that I have posted, the video shows the newer handsets but these are very similar to your 12 button handset, ther are 60+ training clips at http://abbeytelecom.com
Press the transfer button followed by 200
Enter 1234
Press 1 to 'ENABLE'
Press the speaker key
Now press 722 followed by the extension number of the handset.
Type in the number of the button you wish to change.
If it is button 3 then type 03, if it is button 11 type 11 etc.
Once you have done this the cursor will move to the right hand side of the screen.
Next press the letter D on the keypad followed by plus on the volume until it says DS.
When it says DS press the 3rd grey key beneath the screen followed by the extension number. EG DS255.
Once you have done this press the 3rd grey key beneath the screen to save.
Posted on Mar 16, 2011
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
How many different controllers does the ColecoVision system have?
The colecovision comes with a controller thats a joystick with a number pad, but you are able to buy expansion packs that give you a driving controller and a roller controller for more traditional arcade games. There is also the super action controller set that comes with 2 joysticks that have 4 action buttons and a 12 button numeric keypad.
Dec 16, 2013 | Video Game Consoles & Games
Probook 4310s print screen alternative button on american keyboard
If your HP laptop is a wide screen with a full size keyboard and separate numbet keypad then the Prt Scr key also doubles up as the Home key it is located on the top row of keys on the Number keypad.
If your HP laptop is a standard laptop keyboard then the Prt Scr key also doubles as the Scroll key and it is next to the F12 key.
Feb 26, 2012 | HP Computers & Internet
How i lock my nokia e 63
You can lock your nokia e63 by pressing the left key and quickly pressing the action button(small button at the bottom left corner of the keypad) .
You can also press the power button down shortly and then select the second option which say lock keys.
hope this helped you? please contact me for more information.
Dec 31, 2010 | Nokia E63 Cell Phone
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Tried
then i think u shud go to rerair center to chane keypad ic
Mar 15, 2008 | Samsung SGH-E370 Cellular Phone
Keypad frozen, still receives calls
Hi, You don't need 2 flash your razr for this problem. What u need is a screen flex cable. The three buttons around the screen are controlled by a flex cable and the voice recorder is connected on this flex cable.This needs replacing but it's very tricky to deal with. I suggest a really good tech that deals with razr's to handle this problem to possibly replace the flex cable. This would solve yor frozen keypad problem. SAM !
Jun 19, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
62 people viewed this question
Top Samsung Lands Phones Experts
Jose Ma DM.
Jose Ma DM.
imfedup19
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
