Question about Compaq Keyboard
Hot key - Compaq Keyboard
  • 71 Answers
What kind of keyboard? What do you want the hotkeys to do? Go to Control Panel on your computer and you can usually map hotkeys specifically from the Keyboard section of Control Panel.
Posted on Mar 15, 2011
My radio in a 1995 Chevrolet 1500 will not turn off with the key what are some trouble shooting facts
There are two fuses for the radio. One fuse circuit is hot all the time, that circuit is for radio memory and clock, where applicable. The other fuse circuit goes hot with key in acc or on, that fuse runs the radio. That is the fuse circuit you need to check, should not be hot with the key off. If it is hot with key off, either something wrong with ignition switch or that circuit is shorted to voltage, somewhere.
Can you manually turn off the radio?
Jun 01, 2015 | Chevrolet Cars & Trucks
Keybord acer ku-0420
A Hot Key is a short cut key. Ctrl and C will give you the copy command and Ctrl and V paste. The Windows key is a stand alone hot key which gives a short cut to the start menu. Other hot keys come with the relevent soft and firmware supplied with your computer.
Aug 25, 2014 | Computers & Internet
Bought a Pontiac G6 2007 lost the key
The chip in the key prevents hot wiring the car. That is the whole reason for it's use. Forget about hot wiring the car. If you damage the ignition you are looking at a H U G E bill to fix it. If the $50 key is "no problem" why would you risk the EIS system? This key has a transponder chip, part of the security system, inside of the key. Important: this key will require both cutting and programming to you 2007 Pontiac G6 for it to work. It can easily be programmed by a local car locksmith or dealer service department.
Mar 11, 2014 | Vehicle Parts & Accessories
How i can use hot key genius i405
Go to table settings and then choose hot cells and now you will be able to assign a hot key or multiple hot keys.
Good Luck
Mar 03, 2011 | Genius EasyPen i405 4 x 5.5 Active Area...
When/ i/ press/ the/ space/ bar/ the/ slash/ icon/ appears/ just/ like/ this/ message..thanks
Thats a hot key problem. Someone has set a "hot key" on your space bar to make it type that when pushed. Hot keys can be set to do all kinds of things. Like set a combination of pressing two at once to change someones display sideways as a joke ect.
You can turn of hot keys in your computers settings. I dont know what operating system you are running so I cannot give you exact instructions. Just open your help file and type in hot keys and it will tell you where the settings are.
Jan 12, 2011 | Computers & Internet
On my 2010 Toyota Corolla the key occasionally is very hot when I remove it from the ignition. Is there something wrong with the ignition? .The dealer said the Immobilizer makes the key warm, but the key...
The transponder around the key which reads the chip is what the dealer means ,it should not make it excessively hot but it all depends on the person because as a mechanic i dont feel it as hot but the mrs uses a cloth ,so when it feels hot to you ask someone else to have feel as it may not appear hot to them .unless the heater vent is blowing over the key then i dont see why its should get that hot ,could be fault of the model i suppose but this is the first time i have read about this for this model vehicle
Nov 30, 2010 | 2010 Toyota Corolla
I lost my hot keys when i reinstalled my windows
Hot keys were a feature added by your computer manufacturer or other software, not Windows ... you will have to find and install that software to get your hot keys back.
Jun 02, 2010 | Computers & Internet
I cant find the Wifi switch on my toshiba L505d. the only thing I see is what looks like a volume know next to the wifi led but when I turn the knob it does nothing
To enable or disable wireless communication, use the Hot Key
Fn+F8.
To use the Hot Key Cards:
1 Press and hold the Fn key.
The TOSHIBA Cards appear along the top of the screen.
2 Click the Card for the system function to be modified.
The selected Card is displayed full-size with its available
options below it. All other Cards are again hidden from view.
3 Click the desired option.
To use a Hot Key Card using a hot key:
2 Press the hot key associated with the desired function.
The associated hot key card appears at the top of the screen
with its available options below it.
3 To cycle through the displayed options, hold down Fn and press
the hot key repeatedly. Release the Fn key when the desired
option is selected.
NOTE
May 30, 2010 | Toshiba Satellite A215-S4747 Notebook
I need to know where to hook up the key hot wire on a 2005 gmc sierra?
To find where to hook up your power lead. The best way is with an inexpensive test light. You can get one at the local auto parts house. It looks like a screwdriver with a light-up handle and a wire pigtail on one end and instead of a screwblade it's got an ice-pick like tip.
Connect the aligator clip end to a metal grounding location under the dash, and then with the key on, probe with the pointed end on some of the wiring near the fuse block or under the steering column. When the light in the test light illuminates, you've found a hot. Now turn the key off and see if the light goes out. That will be your hot for the the accessory hot.
Then you'll most likely need to find a constant hot. This will be a wire that illuminates your test light whether the key is on or off. This one is hooked to the hot that is constant...it's the one that keeps all your radio stations and the memory items intact when the key is turned off.
So you'll have 2 a constant hot and an "accessory" hot that's only on with the key.
If you need wiring diagrams for your car, let me know.
K
Jul 24, 2009 | Kenwood Car Audio & Video
Compaq Keyboard Logo
48 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
