My Toshiba RDXV59DTKB2 recorder has become unreliable at recording timed programmes onto the hard disk. It either fails to start recording them, or stops part way through. They are still there in the top menu, but with "E9" on the left. Can you tell me what this error code means please?
tvtechnician
  • 105 Answers
SOURCE: Sharp LC-32P70E TV: EPG suddenly not showing
hello, this sounds more like a cable or satelite problem. hame you tried reseting your cable or sat box? usually when you reset the box it will download the guide again...
Posted on Oct 17, 2007
SOURCE: rca drc8295n not recording to disc
The DRC8285N model is a great little machine, however, it will only record to DVD+R 8x disks maximum. If you are trying to record to a 16x, you will not be successful. See page 2 of your manual, and RCA service confirmed it. You can use 2.4x, 4x and 8x only. That eliminates the newer 16x format.
Posted on Oct 25, 2007
SOURCE: DISK ERROR WHEN I TRY TO USE MP3
I had the same issue and just connected the device to my computer USB connection and performed a quick format on the drive and it now works. You will be warned that reformatting the drive will erase all the data, which will happen. But you can simply reload your music and be back in business... Rod
Posted on Apr 19, 2008
  • 3422 Answers
SOURCE: FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Posted on Aug 27, 2008
JULIANFIX
  • 975 Answers
SOURCE: Paqnasonic DVD recorder Model DMR-EZ45VEBS is
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Posted on Nov 30, 2009
No sound, I can record to HDD but there is no audio, why?
i think , there are some virus in ur hdd, ur audio files may be hidden. pls use smadv antivirus free apk. and explore hidden files. it will help u.
Sep 05, 2016 | Toshiba RDXV59DTKB Rd Xv59dtKB Dvd...
I have a Toshiba RDXV59DTKB2 Hdd & DVD/Video
The control board is shot including the on/off switch.
Jan 21, 2013 | Televison & Video
Not recording selected programme from hard disk to DVD
1) clean the OPU optical pick unit.with disk cleaner
2) uninstall the driver and reinstall from your supplier and try again and fix it.the driver can be corrupted.
God bless you
Sep 23, 2012 | Televison & Video
How can i connect my toshiba rdxv59dtkb2 to freesat
be more specific please. Normally you could use A/V cables to your dvd recorder then from dvd recorder to TV.
from your signal that feeds to your tv just feed to the toshiba dvd recorder, then from dvd recorder to tv, then you should be golden. Just dont forget to set the channel on the dvd recorder.
Sep 17, 2010 | Toshiba D-VR3 DVD Recorder/VCR
My Thompson DTR is nearly 2 years old and it does not record any more - even wiped off programmes I had recorded. Shall I just ditch it ?
Nooooooooo! It may be you have no room left on your hard drive. Try deleting some of your recordings and see if that helps. De-select topup tv channels you don't watch (in my case all of them), this can free up to half of your hard disk. Failing that, do a factory reset, hard disk format and retune. You will lose all your recordings, but may well gain your functionality.
Apr 16, 2010 | Televison & Video
Toshiba D-R560KU Fails to record. Error message E-21 E-4 E-4 54037380 Time Schedual starts then fails almost immediately. Using Sony DVD+/-RW disks. Tried from new disks from several different stores.
I read your return email solicitation to me to pay you before any indication that you even have a clue as to how to solve my problem nor even a guarentee should you not be able to. My solution is to block any further emails from your bogus service.
Apr 14, 2009 | Televison & Video
Recording fails to delete
Record another programme so that you have something above the dodgy one in your library. Then go back into your library and press down, blue then green really fast. This worked on mine.
Jan 02, 2009 | Philips DIRECTV H20 DTV Receiver
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
