Question about Bionaire BH3930 Oil Filled Radiator Heater
I have the bionaire oil heater boh2513g. I placed a towel over it to dry and I think it's went into overheating safety mode because the three lights are flashing but the appliance wont come on. Is there some reset button I can press?
    Brigadier General:
  • 4,736 Answers
Turn the Master switch to OFF and plug the heater and leave unplugged for 30 minutes, That should give it time to reset itself. If it doesn't work after that, it's probably fried.
Posted on Mar 16, 2011
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
My bionaire BCH 9208 heater runs fine, but has no heat output. How do I fix this problem?
I have the same problem. This is what I found when I look inside.
I think this could be a quality issue with significant safety risks.
I hope this isn't typical of their products.
Feb 20, 2013 | Bionaire Heating & Cooling
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
I have an Bionaire BPH1520 Micathermic Electric heater which will not heat up. I turned it off after use and now will not heat up when switched on. Digital display still lights up? Is there an internal...
AUTO SAFETY SHUT OFF
The heater has a built in safety device which
will switch off the heater automatically in case
of accidental overheating. It can only resume
operation when the user has reset the unit. For the
BPH1520 (OH)will display in an overheat situation.
To reset the heater:
1. Unplug the heater and wait for 30 minutes
for the heater to cool down.
2. After the 30 minutes, plug the heater in
again and operate normally.
fOR FUTURE REFERENCE HERE IS A COPY OF THE OWNERS MANUAL
http://www.bionaireuk.co.uk/Manuals/MANUALS/BPH1520-UK_43_91313392.PDF
Jun 07, 2011 | Bionaire BPH1520 Micathermic Electric Wall...
Dishwasher isn't drying probably coming up with error three. Can't locate a solution to this. Can anyone help?
I would say a 3 fault is a heater element fault so you water is not getting hot atall. The heater is located in the base which you can gain access to from the front bottom of the appliance but be very careful the base plate is very sharp and will cut you, cover it with a towel for safety. The element is a little tricky to change but not impossible if you have some diy skills. Make sure you tighten the clamps that hold the element to the spray motor as it will leak and then give you an f2 fault. I think the elements are about £40 quid if you do it yourelf.
Hope this helps
Nov 06, 2010 | Dishwashers
Hi, I have a Goldair oil column heater which is a
im sure it has a fuse-able link that will melt when the temp gets to high. it is a safety option
Jun 05, 2010 | Heating & Cooling
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Switch bad?
the switch has gone bad. the switch cannot be repaired but can be replaced
Dec 03, 2007 | Bionaire BH3900-U Oil Filled Radiator...
Heater won't turn on, the lights keep flashing.
HI There is a product recall for this particular model of heater, you can search the internet for details on how to get the item collected by Bionair and get a full refund, these are a fire risk.
Jan 03, 2007 | Bionaire BH3930 Oil Filled Radiator Heater
Bionaire BH3930 Oil Filled Radiator Heater Logo
295 people viewed this question
Top Bionaire Heating & Cooling Experts
Mack Baxter
deton8 von Splosion
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
