Question about Air Tools & Compressors
Need a gasket for the Harbor Freight model 94000, 28 deg framing nailer. the gasket fits between the head and the body of the nailer (4 bolts I think)
    President:
  • Air Tools & ... Master
  • 1,383 Answers
Parts are generally not available for these guns, however you can make a much better gasket (factory gasket was made out of plastic and fails) using material from auto parts store (do not use cork, but paper type). They may not have the right thickness, but using two layers works just fine. Take two layers of gasket material larger than needed (say 6 inch square )and staple them together around edges cut hole in center larger than cylinder and mark exactly where bolts pass thru and vent hole. I use leather punch to punch holes (but any punch will do). Place gasket on body of gun and bolt down head for air pressure test. If test ok you can trim excess gasket with exacto knife without removing head or mark gasket remove head and trim. I usually do not trim too closely as origional gasket on the inside. No need to use gasket sealer. You can even make a temp gasket using cerial box. About three layers of cerial box will work untill moisture enters gun, then over time the cardboard will get soft. Good luck
Posted on Mar 16, 2011
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
How can you get parts for the Central Pneumatic Framing Nailer #69927?
go google and type in-- manufacturer of central pneumatic framing nailer --
you may be able to leave out the framing word as the company will make more than one unit
Apr 17, 2016 | Air Tools & Compressors
How to determine the model number for a central pneumatic nailer
Is it written on the magazine someplace, or sometimes there is some indication on the nose, or call harbor freight they handle that brand name or take a look on google images for one that looks like yours sometimes helps, depending on what you have most bostitch parts will fit other guns. good luck
Mar 12, 2016 | Air Tools & Compressors
How do I find a manual for central pneumatic 2-in-1 18 guage brad nailer/stapler kit 2 item 97524/40116?
Unfortunately, harbor freight retires nail gun models very often. They only list the current nail gun models on their web site, thus manuals and parts are only available for a short time. The only help is that the new models are similar to the old. Sometimes the internal parts are the same but at least the user instructions should be the same. Download various manuals from similar models on their web site today and compare. Do not order parts unless you are sure about fit. As far as orings, you can use generic also from harbor freight (oring kits in standard and metric, not expensive).
Good luck
Feb 15, 2015 | Air Tools & Compressors
Torq settings on 3.7 cyl heads
This is the info for the 2.8d CRDI 2008-11 engine code ENS (51C)
1 Replace Head Bolts
2 Stage 1 Tighten to15 Nm
3 Stage 2 Tighten to 30 Nm
4 Stage 3 Tighten to 85deg
5 Stage 4 Tighten to 85 deg
6 Stage 5 Tighten to 85 deg
Sequence
w93gwmwpatg0gaaaabjru5erkjggg==
If it is the 01-08 model 2.8 CRD engine code R2816K4 then it is this one
Stage 1 - Bolts 1 -18 = 30 Nm
Stage 2 - Bolts 1 -10 = 75 deg
Stage 3 - Bolts 11 - 18 = 50 deg
Stage 4 - Bolts 1 - 18 - 75 deg
Sequence
aa5xdif9xa+aaaaaaelftksuqmcc
If it is the Grand Cherokee then they fit 3.0 CRD, 4.7, 5.7 and the 6.1 SRT-8 engines. I can supply the details if needed. I hope that helps you.
Feb 04, 2015 | 2008 Jeep Cherokee 2.5
I have a central pneumatic roofing nailer model/sku no, 92917, where can i find replacement parts for it??
Sounds like a Harbor Freight tool. Check your local Harbor Freight dealer for parts, however you'll find that buying a new one for under $80 might be the more logical solution! Hope that helps!
Oct 07, 2011 | Air Tools & Compressors
I have a central pneumatic 46240 air nailer. Can anyone tell me where to find a parts list for this.
Central nailers are sold thru Harbor freight. They sell parts for their current models. Easy to check. Go to their web site and try to locate your model number. If found, look at the lower part of the page for link to manual and parts list including 800 number. If your model is no longer available at harbor freight, web site, ask the manager if they have returned nailers that you can use for parts. (they get a lot of tools back) If still no joy, post again with the parts that you need, maybe I can suggest an alternative. Good luck
Aug 31, 2011 | Air Tools & Compressors
Central Pneumatic item 94000 nailer. Need a top gasket and a plastick cylinder ring. Help!
Parts for central pneumatic guns are /should be available from Harbor Freight.com. Call their 800 number for information. If no joy, take your parts to Dewalt service center to try to match parts with Porter Cable framer. Porter cable parts are very close match to your gun. Good luck
Feb 08, 2011 | SK Paslode Sk312 Framing Nailer O`ring...
Where can I find the parts I need
need to check with Harbor Freight about parts
they are the distributors for that brand gun
Nov 22, 2009 | Dewalt D51256K 16 gauge finish nailer kit
Air Tools & Compressors Logo
116 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
