Question about Jabra BT350 Bluetooth Headset Headset
I cant pair my phone with bluetooth it keeps sayn no devces found
    Problem Solver:
  • 14 Answers
It sounds like it may not be in pairing mode properly. I've come across this problem with this make and model before and it does seem somewhat touchy in getting it into pairing mode properly. Follow the instructions in your manaual for 'pairing' very carefully and have the phone ready to detect the headset, as the other problem is that if you do not complete the task quickly enough it drops out of pairing mode. Also have your pairing code (usually '0000') to hand so that you do not waste time when it comes to making the connection. Finally make sure the headset is fully charged BEFORE you try to connect up. Good luck
Posted on Mar 15, 2011
  • 340 Answers
Continously press the power button on the headset for 2 seconds and then try to search from the mobile
How can I repair bluetooth pairing
Depend on your phone brand. Some brand like sony iPhone, in some case can't pair (Bluetooth) with another device
Dec 18, 2015 | Radio Communications
HBH-GV435 Bluetooth Headset not founded on xperia x10i in bluetooth devices?
you should check the headset on other devces first...
Sep 20, 2011 | Cell Phones
I am trying to pair my bluetooth headset to my phone but the phone keeps saying no devices found. What do I do?
Be sure your headset is in pairing mode. Here is a PDF manual for you check out how to pair it to your phone. Hope this helps Fix Ya up.
Aug 11, 2011 | LG HBM 730 Bluetooth Headset Wireless...
Hello...i am using sony ericsson k550 i had a trouble in that i cant send any files through bluetooth my bluetooth is not working pls any one tell how to solve this prob
Make sure your phone and the other Bluetooth device are charged, switched on and within range of each other. Make sure Bluetooth wireless technology is turned on, and that the devices are set to be visible for other Bluetooth devices. Check that the two devices are paired, and have found each other. If there are still problems, you'll have to reset the connection and pair the two devices again.
In some Bluetooth installations, you must activate a COM port manually in your computer. This is done differently for different brands and models of Bluetooth devices. Please see the manufacturer's product documentation.
If a COM port is not activated
1. In many cases, you can right-click on your phone icon in the window where all found Bluetooth devices are shown, and select a 'COM port activation' item in the menu. Make a note of the COM port number of the activated port.
2. Open Sony Ericsson PC Suite and click Tools/Phone Monitor Options.../Com Ports. Enable the COM port you activated in step 1.
3. Keep the Bluetooth wireless technology turned on in your phone, restart the computer and try to connect again.
Feb 08, 2011 | Sony Ericsson K550i Cellular Phone
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Cant pair up cell phone to bluetooth
delete all the searched devices in the list of My device. then try it. if it not work then do a restart of ur phone.
Jul 23, 2008 | Motorola Mobility RAZR V3
Bluetooth problems
Holding down the main button while my phone searched for devices found it. I entered 0000 for the passcode and it connected.
Apr 19, 2008 | Motorola Mobility Bluetooth Hands Free...
Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
Bluetooth keeps flashing
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Sep 24, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
Jabra BT350 Bluetooth Headset Headset Logo
94 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
