I doubt that the switches are to blame - unless they have been damaged or had something spill inside them an accident or the like.
I found a
wiring diagram for the internals of the appliance. You should consult it if you decide to look into the problem. Wires seldom fail along their length - but usually at a connection point. Knowing that, you could look around the inside of the stove but only if you unplug it first. Look for burnt or broken connections at the controls and anywhere they are indicated.. Repair or replace them as needed and reconnect as indicated by the schematic. I'm betting there's a break in a wire at / on one of the connections of a terminal strip or control switch.
Please rate this reply if helpful - good luck! Don't forget UNPLUG the stove before starting!
