I put the disc in the drive follow the instructions then when it asks to plug the USB port in a few secounds after it says "inatallation unsuccessfully please help
  • 1 more comment
  • Sean Newham Mar 15, 2011
    What are you installing?
  • benlaverick Mar 17, 2011
    i tried that but whilst installing it asks to plug the USB in to continue installing.and when i do after it comes up with error 0x0007
  • benlaverick Apr 11, 2011
    PROBLEMS INSTALLING DJ i0 SOUNDCARD
    once installing the device it asks to connect the USB port ( DJ i0) once i do this a little while later a error reading 0X0007
    SOMEONE PLEASE HELP ME
    HAD MANY SOLUTIONS BUT NONE HAVE WORKED YET
  • 1,381 Answers
Hello benlaverick
Do not plug the usb port before finishing full installation of the device .
The best way to get your device running is to delete the software ( if installed , check in Control Panel \ Programs ) , disconnect usb port ,reboot , install software / driver and reconnect usb port .
You should get a confirmation message of successfull installation and the device should run .
Make sure you have installed a compatible driver with your OS .
Best regards
fanaudi
Posted on Mar 15, 2011
  • fanaudi
    fanaudi Mar 17, 2011
    Yes benlaverick , I know but look , someone has just been helpt with my solution .
    I experienced the issue myself with a HP device and the solution was to ignore the CDs instructions and it worked . I don't know what you are trying to install but go to the Control Panel \ programs and look if the sofware appears there . If yes , delete it . Disconnect now the drive you are trying to install . Reboot . DO NOT CONNECT THE DRIVE YET . Install the driver / software . Connect the drive and wait . It should work , provided youn have installed the correct driver in function of your OS . Regards . fanaudi .
  • fanaudi
    Hi again benlaverick . Please let me know if you're still stuck with your issue . Error 0x0007
    is known as a driver issue . If you haven' t yet succeeded in installing your device , try with The Device manager . What does it say there ? Go for a driver update . Best Regards . fanaudi .
Panasonic CF-VDRRT3
Check your connections and cables. From the look of the thing it is designed to work from the USB port on a desktop computer, a laptop gives less power through the USB ports, this is why most USB powered devices for laptops have 2 USB plugs for connection.
Oct 02, 2013 | Computers & Internet
Software is unable to find Olympus Digital camera connected to USB port
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 31, 2012 | Olympus TG-320 Tough 14MP Blue Digital...
Sony 5 cd changer disc exchange system With usb port
All this digital stuff can be more confusing for the user than standard tape systems. You may need to put files on the flash drive that are compatible with the CD changer for the files to be imported. Check the internet about this problem with the model unit you have and I bet you are not the only one having this problem. The flash drive may need to be having cda file son it or maybe something else.
Dec 15, 2012 | Sony CDP-CE375 5-Disc CD Changer
We can't seem to get the camera downloaded to the
images on cameras are stored on a small removable "memory card" usually located near the battery or in its internal (built-in) non-removable memory chip . If you want to access the images through a computer, you have to follow the following procedure:
  1. Usually a cable is provided with digital cameras and can be found in its box. the smaller end of this cable is plugged into a matching port on the camera and the other end is plugged into a "USB port" (the port to which you typically plug in a pen-drive) on the computer.
  2. On doing this for the first time, some notifications will be displayed on the computer
  3. and after a few minutes, you will be able to access the above mentioned memory just like a pen-drive. there will be a few folders and one or several of them will contain the images.
however, the exact steps can differ and it is best that you refer the instructions manual for the exact procedure.
Sep 04, 2011 | Sanyo VPC-S880 Digital Camera
Ihow do i set up my lexmark x2670 PRINTER WITH MY ACER ASPIRE 5532 series laptop
You can download the drivers at lexmark's site here....
Download the file and save to your desktop or somewhere. Run the file and just follow the instructions (clicking next a few times and it will probably ask you to connect the USB cable at some point).
Mar 01, 2011 | Lexmark X2670 All-In-One Printer
How to use verbatim model # usb500
Plug it in one of the usb ports of your computer. Check if the external hard drive has a power button.
Normally, something will pop up on the screen asking you to install the software that came with it.
Follow the instructions and you may now use the external drive as your back up drive.
Jun 08, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Download pics from phone to pc
usually it's plug and play.... plug the phone into your usb port and a menu should pop up asking what you would like to do.... select download pictures to your computer and follow the instructions
May 23, 2009 | Cell Phones
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
