Question about Hampton Bay 52 In. Ant. Brass Redington III¿ Quick Connect Fan w/Remote, Light Kit
If your services are free then only answer this request Otherwise discard it.Need to replace the light fixture or the light sockets(4 of them) with spring tension mechanism instead of the normal screw to hold glass shade, if available.It is Hampton bay ceiling fan Redington3 with four light sockets and builtin remote Model CR552(CH)AB UPC# 718167008462 and other no AAL 0731084 These nos aretaken from the fan itself. The UPC # from manual is 082392345549 for antique brass.I have tried to get the parts via Home Depot with no success. Iwas told that the company which made this parts is not in exhistance any more.Please help me locate parts so I can replace them, My cell no is 703-863-0028. If there is any service charge or any other charge cost involved for my above request to locate the parts,please disregard this request. do not proceed. I do not agree to pay any money for this request and for using your any kind of services.
    Master:
  • 403 Answers
No, no tension mech available. What is the problem with the screws, Maybe I can help with that.
Posted on Mar 15, 2011
Where is the fuse located in the John Deere GT275?
Replacing Fuse
1. Lift hood.
M88565
2. Pull defective fuse (A) out of socket.
3. Check metal clip in fuse window and discard fuse if clip
is broken.
4. Push new fuse into socket.
5. Lower hood.
May 20, 2012 | John Deere Garden
Tip
How to change rear brake light bulb on a 2011 chevy traverse
Open lift gate. Locate two round caps on break light fixture and pry them open. Remove hex screws then light fixture. Twist light socket to separate from fixture. Pull out bulb from light socket. Replace bulb ( i used Sylvania 7443 )
on Jan 26, 2015 | Vehicle Parts & Accessories
I have a 3 bulb flourescent light that had two magnetic ballasts and I want to replace it with a T-8. What is baffling me is that from one set of sockets on one side there are 6 wires, 4 blue and 2 red and...
  • 1 Turn off the circuit breaker that's delivering the power to the light fixture.
  • 2 Test the feed wires with a touch-type voltage tester before you touch them. Press the button on the tester and touch the tip of it to each wire to make sure the circuit is dead. If the tester beeps or lights up then the circuit is still live. Try additional breakers until you find the correct one.
  • 3 Strip about 3/4 inch of insulation from the ends of each wire coming from the ballast if they aren't already prepped for wiring. Use the smallest setting on the wire stripper to prevent snapping the wires when you strip them.
  • 4 Take the single red wire from the ballast and insert its tip into one of the two pressure-slots on top of one of the sockets on the same side of the fixture that the red wire is facing.
  • 5 Take a 6-inch length of similar red wire and strip 3/4 inch of insulation at each end, then insert one end into the second slot on the socket that already has the red ballast wire attached and insert the other end into the other socket on that side.
  • 6 Insert the tip of one of the blue wires into the slot on one of the sockets on the other side of the fixture.
  • 7 Insert the tip of the second blue wire into the slot on the other socket on that side of the fixture.
  • 8 Connect the white wire from the feed circuit to the white wire on the ballast and connect the black wire from the feed circuit to the black wire on the ballast. Make sure the wire connectors are on tight and wrap electrical tape around the connections.
  • 9 Put the fixture back together and install the fluorescent tubes as per the manufacturer's instructions. Turn the circuit breaker back on.
  • Mar 25, 2011 | Kitchen Ranges
    In replacing a broken pull chain (no 3-way power here: simple pull-on/pull-off) on the 3-bulb light fixture of my fan/light combo ceiling appliance, I lost track of how to re-attach the two black wires...
    I assume the switch operates the lights only. Besides the ground (green or bare) and the neutrals (4 white wires all connected together), the only wires of interest should be 4 wires (black) from the fixture and the 2 wires on your switch. Of the 4 black wires, one of them is the hot wire and the other 3 connect to the three bulbs. Connect the hot wire to either one of your switch leads and connect the other 3 wires to the other switch lead.
    If you don't know which of the 4 black wires is hot you can find it by the process of elimination as follows---- connect any three of the black wires together (then supply power), if nothing lights, then the 4th wire is hot. Otherwise 2 bulbs should light. Remove one wire from this trio. If nothing lights, the wire you just removed is the hot wire. Otherwise, one bulb should light and one of these two remaining wires is the hot wire. Take one of those last two wires and connect it to one of the other bulbs. If it lights, then the wire you just moved is hot. Otherwise the one you left behind is hot. I hope this is helpful. Good luck. Be safe! Al K
    Aug 03, 2010 | Westinghouse Electric Ceiling Fan 3-way...
    How do i change rear directional light bulb on a 2006 ford explorer ?
    lift the tailgate
    unscrew the 2 hex screws with a socket wrench.
    the entire back light fixture will now be able to be poped out. Pull slowly and firm on the fixture it will pop free.
    Behind the fixture you will see the wires leading to your light bulb turn a quarter turn to loosen and remove the socket. change the bulb and repeat the steps backwards to replace the light.
    May 18, 2010 | 2006 Ford Explorer
    Intermediate light socket works intermitently, I believe the socket is bad, where can I buy one
    If you've tried other lights in them, which it seems like you have, then the socket could be bad - or you could have a loose wire in the fixture where all the sockets are wired together. This should be easy to get to. And to answer your question, you can get one at any convenience hardware store such as a Home Depot, Lowes, etc. They are a pretty common item. Good Luck to you, and I hope this works for you. Feel free to contact me again if you need further assistance. - Jim
    Mar 28, 2010 | Hampton Bay 52 In.Carriage House II in...
    Driver side dome light fixture popped free into
    Did you ever find out how to remove the dome light counsel, I have the same problem.
    Nov 18, 2009 | 2008 Toyota RAV4
    Need to replace rear left turn signal light on 92 sentra. do I access it from back of fixture (ie, remove fixture) or does outside cover come off?
    Thru the trunk. Peel back the inside covering( may have retainer screws or buttons) you will either see the individual sockets or a cple additional screw/bolt/nuts. Most likely will be retainer buts. remove those and the lens will fallout(be ready to catch it) the replace bulbs as needed and reinstall in reverse order from removal.
    Jul 31, 2009 | 1992 Nissan Sentra 4 Door
    Ceilng Fan light fixture-metal clasps have broken off
    For Hampton Bay ceiling fan replacement parts!!!
    There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
    Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
    Hampton Bay 52 In. Ant. Brass Redington III¿ Quick Connect Fan w/Remote, Light Kit Logo
    113 people viewed this question
    Top Hampton Bay Dryers Experts
    Steve
    Craig Butler
    Craig Butler
    Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
