I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also it starts to aggitate before the tub is filled with water. So when I put my laundry in, add soap, set washer, and close the lid it will start aggitating immediatly, even though the water is not filled and there is still dry clothes in the washer. It will aggitate until the tub is filled then it will start to drain, and go to the rince cycle. The washer does the same thing on the rinse cycle. It will then go to the spin cycle. The washer seems to be draining correctly, but is not running thru the cycles PLEASE HELP Thanks
  • 1,543 Answers
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Posted on Mar 15, 2011
  • schilman63 Sep 12, 2011
    i tried this and the hose is clean but the washer is still doing it!!:(
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
My washer fills,will not agitate,but will spin to empty. why? #2090 ge topload
That dang drive bell has failed most likely. It has a plastic spline in it that wears smooth with time. Yank off the agitator to get to the spline. themobilian_2141.jpg
I have a service manual here
Apr 06, 2011 | GE Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
Washer will fill but it does not stop
Your water level switch is stuck.
Probably due to soap scum in the air dome line.
Remove the control console screws to access the water level switch.
Remove the small plastic hose from the water level switch and blow through it to dislodge the blockage.
If it is difficult to blow through,remove the front panel and take the hose off at the air dome on the side of the tub.
Push a small wire into the air dome to clear the clog.
Replace the hose on both ends.
Set the timer for SPIN and run a spin cycle.
Then retry the water level fill.
If it does not fill correctly,replace the water level switch.
Jun 25, 2010 | GE WBSR3140DW Top Load Washer
Ge toploader will not agitate
check the bell under the adgitator if ok transmission
Jun 23, 2010 | GE WDSR2080D Top Load Washer
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Oct 04, 2009 | GE WBSE3120B Top Load Washer
Toploader washer fills with water then trips
Could be @ the point the heater comes on indicating faulty element, or Motor start indicating motor fault try on other functions to find out which
Oct 03, 2009 | Washing Machines
No Spin or agitation After move
Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
Jul 27, 2009 | GE WBSR3140DW Top Load Washer
GE wbsr1060T washer overflows on 'Super' load size setting
HI, there is a pressure switch for the water level regulation that seems to be malfunctioning in your unit at this time. You will need to replace this switch asap. this will correct this issue.
Click here to order
Jul 26, 2009 | GE WVSR1060A Top Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
