Question about Philips SRU3004 Remote Control
I changed the batteries in my remote, now it doesn't work. What do I need to do?
    Master:
  • 403 Answers
Most likely have to re-program it to your devices.
Posted on Mar 15, 2011
    Top Expert:
  • Philips Master
  • 74,383 Answers
Hello
Codes data which were saved in it was lost during power off time. You have to reset codes for your device or devices to which it was set before, by entering codes to that devices as you have done before. OK.
Remote doesn't work
you will need to take it to your deal for a reprogramming or a key cutting guy that has the computer. try the dealer first as they probably won't charge you (if you get a good guy)
Jun 19, 2013 | 2009 Mitsubishi Lancer 2.0
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Key remote doesn't work
you need to check the remote control door lock actuator (rcdlr) but to do that you need a scan tool may need to take it back to the dealer in my opinion and just because the remote buttons work does not mean its synced to the vehicle good luck
Jul 09, 2012 | 2004 Chevrolet TrailBlazer
Why remote wont work
Change batteries in remote make sure there in right way then point remote at system if doesn't. work then push on buttons a little harder if still don't work may need to check with manufacturer
Feb 08, 2012 | Bose & Wave& Music System
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
The remote for my Tubo Air TAS-12 doesn't work. Are there batteries inside or do I need new one?
does the remote come on? if not then yes i suggest changing the batteries, some remotes have a slide that covers the buttons pull it down and take it off you should see the batteries when that is removed, or some are at the back, let me know if that helps
Sep 24, 2011 | Turboair TAS-12 Air Conditioner
My remote will not operate my tv ?
you may need to change the remote code to the one for your model tv, or replace the batteries. instructions for this should be in the manual that cam with the remote.
Jun 16, 2011 | Sharp Televison & Video
Remote doesn' turn n tv or chane channels
try changing the batterys. If its a universal remote reprogram it again.
Oct 04, 2009 | Symphonic ST420FF 20" TV
Philips SRU3004 Remote Control Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
