Question about LG Refrigerators
I am trying to replace my ice maker which is broken. I can not find the correct model ice maker anywhere on the internet. My ice maker for model LFC25770SW/05 is a top mount in the freezer, not a side mount. All I can find are side mount makers that do not look like anything I currently have. I bought this refrigerator at Sears in November of 2009. The Sears parts department as well as the LG 1-800-243-0000 part distributor number are no help either. At least provide me with the CORRECT part number for a TOP MOUNT ice maker. Please help and Thank You for your time.
Go to your local appliance repair shop, not the big stores. They should be able to steer you to the right icemaker. Most of these (not all) are generic. They should be able to help you for about $100.
Posted on Mar 15, 2011
Ice maker broken.
Google search your manufacturer make and model and the word service manual. If one is available, you can find it in the search results.
Since you mentioned that the replacements are discontinued, unless you find a similar model to pull a part from, you may have to plastic weld or glue the broken part.
Mar 16, 2015 | LG Refrigerators
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Model GSH25JSRFSs Refrigerator is clicking behind the Ice maker , and the lights flash when it clicks
Then I think you better disconnect the ice maker=> WR30X10093 Complete Icemaker What it sounds like is happening is the ice maker is binding possibly because the heater used to preheat the ice slots are not allowing the ice to be ejected once the ice ejector forks try to move the ice to the ice bin. This can also be the ice maker is worn out and the motor that pushes the ice out can also be the cause of the problem. First turn off the ice maker and if needed disconnect to prove that the lights stop flashing or dimming when the ice maker try's to eject. That will tell you what the problem and location are most likely the cause and reason. Unfortunately your model WR30X10093 Ice maker has no replaceable parts. You are welcome to get your repair parts anywhere you like as I am here to assist you and answer your questions. Should you have any questions please ask so I can help you, Thank You, Sea Breeze
Nov 11, 2011 | GE Refrigerators
The model for Scotsman ice maker is AFE400A-1B and it stop making ice. Can you help me diagnosis?
If your ice maker has stopped producing ice completely first unplug the ice maker and then check it in this order.
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:If your ice maker has a small red plastic lever, lower it to lower the wire.If there's no plastic lever, simply lower the wire.In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Mar 15, 2011 | Scotsman Ice Maker WBin Flake Style water...
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Gold Ice Maker problem Model # GS6NBEXRS00
I hate to ask the obvious but is your water supply turned back on since the filter change?
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Deni blueberry 5201 Ice cream maker...
While I can't tell you where to buy a replacement paddle, I can tell you we just bought this model of ice cream maker through Heartland America for $30. If all else fails... Hope this helps!
Jan 12, 2008 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
Refrigerators Logo
105 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
