Question about Xerox Office Equipment & Supplies
When you switch on machine it initialises and start booting. Suddenly it fails and error speed configuration appears
    President:
  • 2,072 Answers
Without knowing the model number I cant tell you what to do.
Posted on Mar 15, 2011
Plotter fails to boot normally.
I would get it repaired by an authorised repairer. Sounds like the IO board has failed.
Jan 07, 2016 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
My compaQ dx6120mt desktop initialising ram but not booting
when you boot does it pop up with any additional information such as "No bootable disk found" or "corrupt MBR"
If you get no bootable disk it is the HDD has failed
if you get Corrupt MBR then you need to reinstall windows
if nether of these appear and the system just hangs on the DOS start screen then it could possible be your RAM at fault
Mar 13, 2014 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I start the machine and after 5 seconds give me the 116-324 error code
Thats called an exception error. One of 2 things. Either it needs a complete software upload, or the network control board, called the ESS board has failed.
You can try these steps
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
The last one IOT ESS NVM will clear all your netrowk settings.
May 07, 2011 | Xerox WorkCentre M-24 Color Copier
Windows stop and nothing happin
hi If able to load win XP or any operating system that mean your system is booting and is in good condition. if there is issue with load of OS in normal mode then you try using last used configuration. follow this steps
1) keep press F8 when bios screen goes off until you see win xp option
2) then choose "last used configuration".
it will try to boot the system even though the system does boot properly then repair the os by booting xp dvd or cd from cd & dvd drive.
i hope this will resolve the issue.
Jun 25, 2010 | Mercury P4VM800M7 Motherboard
When I turn on my computer the first thing I see is Sony Ericsson error in configuration. This does not appear on my 'phone and does not seem to affect anything but I just want to know what it means please...
This might be some failed software link. You can find these softwares link on start up at Start->All Programs->.Startup in startup remove any entry that looks like Sony Ericsson.
Also, if XP you can go to run and type "msconfig" and hit enter - on System Configuration Utility-. goto "Startup" tab and remove/uncheck any entry that matches error you receive frequently after booting up. This should solve the prob
May 13, 2010 | Computers & Internet
ERROR CODE
you may use boot to "last know good configuration" try to reboot the computer once again, then while it is initiating, start pressing "F2" until a menu appear, now select "last know good configuration"
this method may depend on what is the type of your motherboard, but usually it is F2 or F5
should you have other questions, just let me know.
Aug 05, 2008 | E-Machines eMachines Desktop PC
Error message #1
I had the same problem. It was plug ed into an extension cord as soon as i plug-ed it into the wall socket presto it works. I sure hope your problem is this easy.
Jun 20, 2008 | Janome Memory Craft 5700
Compaq evo n1050v laptop rebooting on XP startup
When you start it hit the f8 key,highlight safemode without networking.If it boots do a system restore.
Feb 28, 2008 | Computers & Internet
Canon np6030 copier
Does the machine start and switch itself off? Some errors cause this to occur to prevent further damage. Try switching it on with the front door open, this will prevent the fixing heater circuitry from initialising. You will then need to find the error code. The ones that cause it to switch off never appear on screen, only viewable thru service mode. Push a straightened paper-clip into the hole below the right hand meter inside the front of the machine, press << and >> to get to *1* DISPLAY, find ERROR and let me know. Hope this helps...
Aug 29, 2007 | Canon imageCLASS D761 Copier
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
