Question about Whirlpool Washing Machines
Wont spin or agitate - Whirlpool Washing Machines
  • 59 Answers
If this is a top load washer and you hear the motor running during these cycles you most likely have a broken drive coupler you will have to remove the front of the machine by first lifting the console here you will find two spring clips pop them out with a screw driver then pull the housing top towards you and then out at the bottom remove the two clips holding the pump to the motor and move to the side. it is not nec. to disconect hoses. remove the two screws and clips holding motor disconect wiring and remove motor you will see drive drive coupling you local parts distributor will have a replacement coupler. and are not hard to replace. use a drift and tap in the center when installing to make sure you dont damage the hub reinstall motor and pump and casing and test . if motor is not running you may just need a new lid switch .
Posted on Mar 15, 2011
I have a700 series top loader washer,and the agitator wont agitate,it will spin,but wont agitate why?
The agitator itself is stripped or loose is one possibility. Take agitator off to see if it is damaged.
Jun 03, 2014 | Washing Machines
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
Feb 08, 2011 | Frigidaire FWS1339A Top Load Washer
Washer wont spin....it agitates and drains but wont spin when it gets to the spin cycle. timer still moves.
Tough to say without doing some testing. First thing to check is the coupling. It may sound like its agitating and may not at all. IF it really does agitate and won't spin, I would start diagnostically testing the timer. That isn't something your average homeowner can do though.
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
I have a Kenmore washer tube wont move to spin out
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Jun 27, 2009 | Washing Machines
Wont spin
just the agitator wont spin? take the top off it, then you pull the cap off. there should be a bolt down there to take off. then pull the middle half off and replace th 4 agitator dogs.
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
WPSR3120 agitator wont spin
just pull up very hard with a hard ****
May 11, 2008 | GE Profile WPSR3120WWW
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
