Question about Kenmore 24 in. 16032 Built-in Dishwasher
It is burned. Is the rest of the machine ok, and how much does a new control board cost?
  • Kenmore Master
  • 8,404 Answers
My son in law just had a similar problem. It cost him a little over $250.00 US to repair. He should have replaced the machine.
FixYa.com is not a place to purchase parts directly. Parts are sold through partnered advertisers. There is also a section here where you can ask for "local repair". If you post your question in that section, a repair shop in your area will likely see it and give you a call, though there is no guarantee of that service.
You of course can call your local Sears store and get information on repairing your Kenmore 16032.
Thank for your interest in FixYa.com
Posted on Mar 15, 2011
My LG front load washing machine, model WM3001HWA, has no power. What can I do?
Hello Kyle;
My name is Peter. I am a retired field service appliance technician.
You have 3 sensors in your unit, a thermal sensor, a position sensor and a door lock switch. These components will prevent you from running but, would not affect your power.
I assume you checked your circuit breaker to make sure you have power to your washing machine.
The slightest change in power supply, electrical power surge or power outage will knock out your boards. Magnetic fields and static electricity will knock out your boards. Are your appliances near a main power supply line in your home?
All appliance manufacturers recommend surge protectors if you have control boards in your appliance. Individual wall socket surge protectors cost about $20.00 at your local Home Depot or where ever. This is a good investment.
Ok, your have 3 control boards in your unit. One is the digital display board which has nothing to due with power supply.
The others are your main control board and your control panel board. Each of which can turn off power. The highest probability is the main control board. The part number for this board is EBR 44289820. The part cost $225.00 locally. You can probably get it for $180.00 if you search the internet. This is item A450 on the following link.
Remember static electricity can not out a board. Ground yourself by rubbing your hands over something that is steel. Either unplug your unit or turn the power off at your household fuse box. There are several clips holding the board in the casing. you must push outward to remove the board. Inspect the circuit back side for burn marks. If there are no burn marks you can still have a board component failure. DO NOT DISCONNECT ANY CONNECTOR PLUG IN. When you replace the board, you will replace one at a time.
Nov 23, 2014 | Washing Machines
Fault F 02
F02 is listed as a motor
jammed or tacho failure.
Check that the motor is not siezed or damaged. Try turning the drum by hand. Does it turn easily and freely? Are there any strange noises from the motor area?
Check for broken wires from the motor plug to the main control board.
Check the main control board for signs of damage or burning.
Check that all plugs are firmly seated on the control board and into the motor.
If there's nothing obviously wrong I'd check the carbon brushes in the motor.
After that, if it's all checked out ok, time for the engineer.
As it could be costly on parts, ie. possibly a motor and a main pcb.
Apr 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
My maytag washer does not spin out, the clothes are still wet
if it is still tumbling in wash cycle,the motor and motor control board on the bottom are OK.The problem will be in the main control board in the top consol.board should then be replaced.If tub is not moving at all it could be the motor control board located on the bottom of the machine in front.When this board goes bad you can usually see signs of burning parts on the board.This part will be replaced with an upgrade kit consisting of a new board and new drive motorfor around 275.00 approx
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag neptune mlg2000aww door will not lock or spin
Removing the top cover of the dryer, you will find, in the front right, the machine electronic control board with a burned resistor. This resistor burns up when the washer lock motor fails. The lock motor and control board will need replacing. Parts cost will be around $220.00.
Feb 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 24 in. 16032 Built-in Dishwasher Logo
53 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
