Question about Euro-Pro Sewing Machines
My euro-pro 392/392w. my needle does not pick up thread from the bobbin. and yes the needle is in the right way I tried all the simple things that it could be but no luck still not working.
  • 3422 Answers
SOURCE: Euro Pro 9105 won't catch bobbin thread
first of all make sure you have the needle in the correct way round, flat side facing back, try a new needle, it only has to be slightly bent or blunt and it will miss stitches, the tension unit is the small piece near the takeup lever and it only has a small spring but that has nothing to do with the threading picking up, if the machine misses stitches after trying the above then you will need to retime the machine either bu a shop or by yourself, if you are sewing on fabric that collects static such as knitted fabric make sure you use an anti-static needle otherwise it will miss stitches.
Goodluck..
Posted on May 23, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
SOURCE: needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Posted on Feb 18, 2009
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
SOURCE: Need Euro-pro manual asap. Needle won't pick up
T o adjust timing it is very simple. You are going to need Alan keys, just one specific one. This is for the euro pro shark X, many are the same it may work for you. Take the casing off the back of the sewing machine. A few screws is all. This reveals the back of the bobin casing. In the gear there are two small holes with alan keys in them, losen these up, this will free up your hook so you can place it where it needs to be. (www.sewusa.com). Adjust to place and then tighten back up alan keys. Finished.
I hope it helps as it just took me a while to figure out.
Adrian
Posted on Feb 01, 2010
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Needle not picking up bobbin thread how can I fix this ?
Try installing a brand new needle. Sometimes a bent/damaged needle will not pick up the bobbin thread.
Check that the bobbin thread is loaded properly.
If the problem continues, take it for service as the needle/hook timing can be off.
Apr 16, 2016 | Euro-Pro Sewing Machines
Bobbin will not pick up needle
when you insert the bobbin into the bobbin case and insert into machine, make sure there is a long tail coming out of the bobbin.
Thread machine correctly and when trying to "pick-up" the bobbin thread, make sure you are spinning the flywheel the right direction.
Jul 20, 2014 | Euro-Pro Dressmaker 998B
How to thread euro pro 380a sewing machine lost mannel
My needle will not pick up my bobbin? I have tryed everthing! my bobbin was placed in the holder right. my needle is in the EP correctly! not sure if my Thread is correct in my machine. but I have read the manual and still cant get the needle to pic up. Can some one help me out on this! Euro-PRo 380A
Dec 16, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Needle does not pick up thread from bobbin
Is your needle inserted with the flat side facing the rear of your machine? Are you holding your top thread as you rotate your handwheel toward you to lower the needle? Is your bobbin threaded right, check your manual. It is usually something very simple when this happens.
Sep 09, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
You have knocked the machine out of timing, the shuttle and needle timing needs to be reset.
Oct 14, 2009 | Sewing Machines
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
Sewing Machines Logo
55 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
