Question about Dishwashers
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and it ran OK, I also checked the pipework out for any blockages, it all looked OK, I put it back together and tried it out it went through a wash cycle everthing looked OK, but there was still a lot of water in the bottom, and it will not start now, I took all the water out and still it will not start,
    Master:
  • 238 Answers
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
Posted on May 23, 2017
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Posted on Jan 11, 2009
  • 1214 Answers
SOURCE: Hotpoint is not taking water inlet
If your thinking air in the water supply line, air won't be the cause. I would look to make sure there is not mineral buildup inside the valve, and that the valve is good.
Turn the water off, disconnect the line at the water valve, then carefully tirn the water abck on to make sure there is good flow from the water supply line. If there is, then look toward the dishwasher side. If not, look toward the water supply side.
Posted on Jan 24, 2009
SOURCE: A screw fell inside the
try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE problem.First disconnect all power ( power supply, circuit breaker, wiring etc) to the machine. Disconnect all tubing to the machine ( drainage pipe and braided hose feed) Then you need to take out the dishwasher, turn it over and then remove the large white sensor tray that will expose the leakage sensor held on by 2 screws. Remove the screws and dry up the sensor tips (4) with a dry towel and dry up the tray all around as well. Replace the tray and re connect all tubing and power. You're problem should be solved and you just saved yourself a pile of money in service repair bill. M.D.
Posted on Jan 02, 2011
  • 31 Answers
SOURCE: My Hotpoint BFI680 dishwasher trips
This is caused by having a dryer element, if you are able to get to the back of the element look for where the wires connect to it, I am almost positive the element is bad, always turn off the power when looking at any electrical unit to service , if not sure use a tester, you should have zero volts at the connection box near lower right hand side near floor. you can get this element from here if you have all the information on this unit, http://www.appliancepartspros.com/ you can also email me at glipsky@tampabay.rr.com good luck
Posted on Jul 26, 2011
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
How do I reset my Hotpoint dishwasher (Model FDD914K.R)?
Cleaning the filters is straight forward and should not require a reset
I suggest you check the water supply to the machine as it may be air locked preventing the start sequence from operating.
Hotpoint dishwasher Model FDD914K manual Google
Apr 13, 2016 | Hotpoint Washing Machines
How so i start a hotpoint BFI680
Uhm... This is a dishwasher, right? Your user manual has the instructions in it. If you don't have one, you can download a pdf of your manual here:
http://www.devicemanuals.com/support/pdf-manual-124551.html
Just click on one of the stars to rate the service and then click on the "trial download now" link to open up the PDF in your browser.
Oct 19, 2014 | Washing Machines
Dishwasher will fill and empty but no water coming through the spinners
It would help if you provide the model number.
Usually the problem is with the wash distributor circuit. The water alternates between bottom and top spinners (wash arms). The distributor may be faulty assuming the arms are clean and you have checked this. Some models use the same pump for wash and drain using impeller. In that case the problem could be the impeller is clogged and not allowing water to get in the arms. See this diagram.
Model number will help identify the part.
Dec 29, 2012 | Hotpoint Dishwashers
Hotpoint LFT 228 A dishwasher intermittent draining problems. Sometimes so much water that it leaks, will drain sometimes but then water appears in the filter again, items in dishwasher sometimes come out...
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
Sep 25, 2011 | Hotpoint-Ariston LFT 228A 23 in Builtin...
It does not clean well. my uncle took out the
improper loading can sometimes cause this problem.
On most models, a wash tower rises through the center of the bottom rack during the cycle. Do not block the circular opening through which this tower rises. Also make sure your water is hot enough. at least120-150 degrees F. you may also try running the hot water at the sink before starting the dishwasher.
Jun 03, 2010 | GE 24 in. Profile PDW7800 Built-in...
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
After drying there is water in filter trap is this normal
IF THE WATER IN PORTABLE DISHWASHER AT THE BOTTOM IS MORE THAN THE DRAIN HOSE FULL OF WATER THEN ASK WARRANTY PEOPLE. WHEN PUMPING WATER UP IT CAN ONLY PUMP SO MUCH WATER OUT OF HOSE BEFORE THE WATER DRAINS BACK INTO DISHWASHER.-- HOPE THIS HELPS
Mar 08, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Nov 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Aug 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
