My toshiba satellite pro a210 1az just stops after about 10 mins of use. the power light stays on but it is as though it has gone to sleep but the only way to get it to do anything is to power off with the button. Any ideas what is causing this? Please help!
  • 41 Answers
Check if its in the hibernate mode instead of sleep. there's a short cut key to resume for hibernate check the user's guide in the laptop manufacturer's website.
Posted on Mar 17, 2011
Toshiba Satellite Pro L300 Restarts its self after few hours when in use
Have you cleaned the fan and vents? Plugged in or Battery? Open Control Panel, Power Options, Set to High Performance, Open Advanced Power Settings, Set Sleep and Hibernate to Never, Adjust advenced settings to your preference.
Jan 23, 2013 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
This past week I havent been able to put my Toshiba into sleep mode. It's a Satellite Model# A215-S4747.
Try removing the battery, removing the RAM, leaving like that for a few mins, and then put back the RAM, carefully, and the battery, connect to power and hold your finger on the Power Button until it boots, then go into the Power Settings properties, and set your "Sleep" and "Power Saving", & "CPU &Screen" settings from there. Reboot and now you should have your sleep function back.
Feb 25, 2010 | Toshiba Satellite A215-S4747 Notebook
I have a Toshiba Satellite laptop and it's about 10 years old. That's why I need to plug in to my ac adapter in order to turn it on. But now, even when I have the ac adapter plugged with my laptop, the...
Nothing! Yellow light indicates a depleated battery. My guess is the battery is shot! The laptop is still working and the yellow flashing light has no affect on the usability. Buy a battery if you want it to stop! They are real expensive and may not be worth doing. Keep using the laptop as is.
Dec 04, 2009 | Toshiba Satellite Laptop with Intel...
sounds like charger is gone , can you hear a humming noise from your charger when you press it againts your ear, if so it seems ok if not its gone, you can search ebay for a charger and they are very cheap.
hope this helps
Dec 04, 2009 | Toshiba Satellite A105 Notebook
Toshiba satellite pro 6000 power
Sounds like a bad motherboard to me - assuming that it has memory installed.
Nov 29, 2009 | Toshiba Satellite Pro 6000 Notebook
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Troubleshooting with Toshiba Satellite A75-S211 Notebook
try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
Help!!
Sounds like its in sleep mode.
Hold in the power button for at least 10 seconds. That will power it off :)
Oct 12, 2007 | Toshiba Satellite Pro M15-S405 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
