I have an HP4280 and would like to know how to print envelopes that come out straight. Is there an adjustment I can make because the printer looks like it's making the appropriate adjustments but sometimes the address comes out looking crooked.
  • 77 Answers
Sir plz adjust ur page setup from your working software and then print
Posted on Mar 15, 2011
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
How do you print envelopes on the Canon Pixma iP4600. What feeder do you put the envelope in? I need to print on square envelope 155mm x155mm and don't want the envelope to get creased.
I print envelopes a lot for my business.
What I do is I use the regular paper feed, and I open the flap on the envelope so that it's flatter. Simply slide the paper guide to adjust to the size of the envelope.
Also, typically the orientation for printing envelopes is sideways. You put the left edge of the envelope in the printer first. If you are unsure of the orientation, simply do your first print on plain paper. Then you'll know how to insert the envelope.
Oct 09, 2009 | Canon PIXMA MX310 All-In-One Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Envelopes
You need to bring the guide in so the printer can pull in the envelopes properly, else it will print side ways.
Aug 17, 2009 | HP PhotoSmart 7760 InkJet Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
Printing business envelopes
The printer does not need to be set up really, its all controlled by the software you use ie. Microsoft word. Just put the envelopes in the envelop feed if it has one or take the paper out of the tray and put the envelopes in (adjusting the side guides to fit). In microsoft word there is a function to print envelopes
Jun 19, 2009 | Samsung ML-2570 Laser Printer
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
44 people viewed this question
k24674
jasbo
jasbo
