Question about Rowenta DG5030 Iron
My dg5030 is leaking steam at the water tank cap. have replaced the gasket
5 Suggested Answers
SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
Posted on Jan 23, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
SOURCE: I ordered replacement gaskets for
need to replace the cap assembly cs 00098581
Posted on Nov 04, 2010
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
Posted on Nov 08, 2010
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
Steam is coming out of water fill area
Where did you purchase a new cap, mine was accidentally broken and can't find a replacement.
Apr 22, 2013 | Rowenta Pressure Iron and Steamer DG5030
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
My rowenta dg5030 is leaking at the cap
Oct 14, 2010 | Rowenta DG5030 Iron
Jan 10, 2009 | Rowenta DG5030 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta DG5030 Iron Logo
47 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
