Question about Watches
I thought the wenger 79137 had a screw down crown, it just keeps on turning??
  • 77 Answers
The spring is struck in your watch open your watch back cover and then put back
Posted on Mar 15, 2011
My Wenger Military watch face rotated 180 degrees, is this repairable?
Yes, remove the back and the crown. Lift it out and turn it. 4 minutes in your local jeweler and about 20 bucks with a new battery.
Means you can wear it left or right handed.
Nov 28, 2017 | Wenger Watches
How do I set the day when it shows LUN?
LUN is French for MON - so either learn the French terms or find the manual
Dec 06, 2014 | Wenger Swiss Military Classic Watch 79137
Casio edifice EF527D-1AV
Do you realize that this watch has a screw down crown to keep it waterproof?
Hold it in and turn it clockwise to lock it down.
Let me know if this helps.
Mar 11, 2014 | Casio Mens EF527D-1AV Edifice Stainless...
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 | Watches
Cannot set time for time for tag heure CL111a
You probably have a screw down crown. Turn the crown counterclockwise and unscrew the crown. Now you should be able to pull it out. When tightening it back down, don't over tighten, just snug. This is to keep moisture out of your watch. Always have it screwed down unless you are setting the watch. Nice watch, Michael
Nov 05, 2011 | Watches
Screw down crown wont screw down
Either the crown or the case tube threads are stripped. Which ever part is stripped needs to be replaced. Keep in mind that both could be the problem. Be sure you don't get your watch wet until this is fixed. Your watch is NOT sealed for water resistance if the crown does not screw down.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 02, 2009 | Tag Heuer WAH1112.BT0714 Formula 1 watch
The second hand on my chronograph will not index properly when reset
Try this or some variation as it worked with my new Wenger Chronograph.
Pull the crown out to the first position (for changing the date) and press the top button - one of the hands - either the big second hand, the little minute hand, or the little tenth of seconds hand - should move one notch. Keep pressing until it reaches the desired position. Now press the bottom button, same process. Pull the crown all the way out and press the top button, same process. Then if that still hasn't solved it, crown all the way out and press the bottom button. Each position should correspond to a hand, and each press should move it one notch. When settled, push the crown all the way in and operate it normally.
Be careful not to press buttons when changing the date or time, and don't bang or shake the watch too hard while using the chrono. Also, don't play with the buttons or press them one after the other too quickly.
Oct 30, 2009 | Swiss Army Wenger Wenger watch
Wenger Swiss Military Watch: small set-time handle fell off.
That small gizmo is called CROWN or WINDING CROWN. It is not possible to obtain it online, so, you have to shop around for it. Find your nearest watchmakers shop and ask for replacement. You may need stem as well.
Rate, please.
Jul 09, 2009 | Watches
How to set the date on luminox 3600 series watch
it has a screw-down crown, you have to turn it counterclockwise until it pops looses slightly, then you can pull the crown and set time...dont forget to push and rescrew it down to case to keep it water tight :)
Jul 09, 2009 | Luminox 3007 Original Navy Seal Diver...
Setting time Wenger Swiss military brigade hinged crown protector
The crown protector is hinged on the lower end only. The upper end can be pulled away to expose the crown for time setting.
Feb 02, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Watches Logo
27 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
