Question about Honeywell Heating & Cooling
My heil high efficientcy 5000 furnace stopped running, I checked the pressure switch and repaced the siction hose. That was not the problem. The motor hums for a while and then it switches off the motor never kicks on.
    Genius:
  • 1,015 Answers
If the induced draft motor does not come on first then thecontrol board will not let it go any further. I would replace the draft motor and hopefully that will fix your problem. Good luck and thank you
Posted on Mar 15, 2011
Furnace wont run until i pull a hose from the pressure switch
ok that switch is called proving switch and if it runs when you pull hose off that means switch is stuck-, normal ops- call for heat power fan inducer start and closes proving switch normally two are a dual switch positive connects to fan discharge and negative connects to heat exchanger (fan suction )this is to insure air movement threw heat exchanger( pressure differential )then and only then a trial for ignition starts check for clog in other end of tubes
Feb 21, 2014 | Honeywell Furnace Air Pressure Switch...
My heil heater is not firing up
take the hose off the exhaust fan assemby and suck on the end and you should hear it click try sticking a paper clip or something like in the hole where the hose coonnect on the exhaust hosing sometimes some junk just gathers there
Jan 18, 2013 | Honeywell Furnace Air Pressure Switch...
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
I have a Heil H9MPDO75F2AZ QUIET COMFORT FURNACE and have replaced pressure switch and still not running
Hi Kim,
A couple things to check:
1) OK, you've replaced the pressure switch - good stuff. But the neoprene hose running from the pressure switch to the inducer motor... does it have any tears or cracks? Is the hose fittings clogged on the inducer side? Clean/replace as necessary if so. You cannot have any leaks or restrictions in this hose.
2) Try disconnecting the inducer (spent fumes exhaust fan) motor and check this motor coil for continuity with a multimeter. If the motor coil is dead, you'll need to replace the inducer (about $120.00?).
3) Check during initial startup of a heating cycle that there actually is 120vac arriving at the inducer motor coming in from the control board. If not, your board may be at fault.
Hope this helps!
Papa Fixit
Oct 25, 2011 | Goodman GMS90703BXA Heater
Just replaced inducer motor, runs great but furnace will not ignite
Check the pressure switch and the little hoses going to the pressure switch. If the pressure switch does not get a vacum from the blower it will not let the furnace light.
Heatman101
Mar 03, 2010 | York Furnace Draft Inducer Blower Fasco #...
Furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Oct 17, 2009 | Heating & Cooling
Heating & Cooling Logo
211 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
