Question about Video Game Consoles & Games
The ps3 is on and the red light is now green i have my controller hooked up with the charging cord but i cant open the system to put a game in it keeps beeping when i press it
  • 659 Answers
Push the eject button for 10 seconds. then you should hear some noises inside the drive, the disc will come out and after that everything should work I hope thats the easyest of the solutions the next would be to physically open the console but try that first and let me know if you feel upto the challenge I will give you the procedure to do so.
Posted on Aug 01, 2008
PS3 console don't start
One of 2 problems. Either, you don't have the cords hooked up correctly, or,,,,(RLOD) Red Light Of Death. This usually happens from losing the heat sync properies between the APU or CPU. Please check out the many vids on YouTube available for the RLOD FIX.
Mar 04, 2014 | Sony Playstation 3 (PS3) Console
My dad cant hook mine up for some reason
Ok
First, Turn your T.V. on and go to the input mode on the t.v.
Second, there should be two cords in the back of your playstation3.
The power cord and the input cord. These are the two basic cords to turn your playstation on.
Once you have them plugged in, on the back of your playstation 3 there should be a power switch right above the power cord. Click it on so that the I is down and the O is up. In the front of your Playstation, a red light will appear indicating that the Playstation is ready to be turned on. Tap the red light until it turns green ( this should only be tapped once) When it is green the system will go to the start-up menu and enjoy your Playstation 3
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
Only Green Lights PS3 dont turn on
Usually the "red light of death" on the PS3 as it is called by some people is due to hard drive (HDD) connection errors. Here are a few things you can try to do to fix it and get your console working again as intended, just check out this short video I made (it's less than 4 minutes and contains useful pictures etc)
For more information and advice on how to fix your console, if that does not do the trick for repairing your system, check out my PS3 red flashing lights repair blog.
Hopefully you get your PS3 working again ASAP!
Regards,
James Philipson
Jul 13, 2009 | DreamGear Lava Glow Wireless Controller ...
When i turn my ps3 on,red light goes green then red right away
Try disconnecting your PS3 and then for 10 seconds if that doesn't work, disconnect all jackets meaning all usb connection ports connected in it. Remove them, then turn on your ps3 see what happens (without using the controller), then disconnect the ps3 cord that connects to your extension cord or jacket and plug it back in. Try it again. Then again with the controller could try. Try disconnecting other ports such as other stuff like as listed, Irons,Fans, etc.           !!!!!!DON'T USE TOO MUCH POWER!!!!
The Same thing happened to me on my Wii though.
If nothing works call Customer Support (SONY)
May 30, 2009 | Sony PlayStation 3 40GB System
Ps3
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
insetad of restoring the filing system, restore the default settings ore restart the system
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
No sound or picture for ps3
You both sound like you have an over heating issue. Mostly if the fan does not stay on. The PS3 always has a fan on, just the first setting is very quiet. Do you feel any air being blown out of the back (where the power cord goes in)?
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
44 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
