Question about Electrolux EL5010A Bagged Upright Vacuum
Have an old upright that does not pickup dirt. The beater bar runs but the suction motor doesn't. Do not know how to disasemble upright.
  • 694 Answers
I don't recommend taking it apart yourself. The problem could be a switch, wiring, or connection. The motor could also be bad. I strongly recommend taking it to an authorized Aerus Electrolux store for a free diagnosis. Let a trained service tech fix the problem. Just be prepared for them trying to give a sales spiel. That's their job.
You can also call the shop and ask for someone to come pick it up. There should be no pick up and delivery charge. Just make sure in either case you get a copy of a work sheet with the type, model, and serial number recorded. This avoids possible confusion in the shop as to which vacuum is whose. The service tech will call you with an estimate for repair.
Disassembly is tricky, and reassembly even more so.
http://www.aerushome.com/storelocator/
Posted on Mar 15, 2011
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
Power only comes on when vacuum is not upright
Power or beater bar? Beater bar is supposed to turn off when upright, but suction motor should still run.
Nov 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
It has no suction...
Assuming that the vacuum will run, remove the bag and check the discharge to the bag from the machine for debris. Also check the suction to the vacuum blower by removing the beater bar cover plate and beater bar. Inspect the belt. While the bar is off, inspect the suction hose behind the beater bar. This is where I usually find the debris.
Regards, --WoobieDog--
Jul 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
DC07 works with the hose - but not when upright
Check the actual brush bar is moving. If it is then there's definately a clog and it could well be behind the beater bar. If you can remove the sole plate (which is the grid in front of the beater bar) then undo it and check dirt behind the beater bar, belt and main dust channel. Also check the main inspection air ways and if the beater bar is clogged with hair, clean it off.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
No suction in an upright position
If there is vacuum at the point you described, then you need to look down inside where that round port connects to the floor head, all the way out to the beater bar. You may have to take the plate off the bottom to look all the way through to where the round vacuum port connects.
Let me know what you find. But the key to fixing this is to think about the direction of air flow as it travels to the vacuum motor. You've correctly identified one important operational fact (vacuum at the round port). Now we have to find the problem, and you are the eyes and ears of that investigation.
Jan 30, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
No upright suction
This means that you have something plugging the main camber where the dirt enters through beater bar head.check that out. biigg53566
Jun 24, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Electrolux EL5010A Bagged Upright Vacuum Logo
85 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
