Question about Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator
Have constant metallic vibration inside my 3-yr. old Samsung fridge. tried levelling; doesn't help.
  • Samsung Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Mar 19, 2011
How do I get my Android Galaxy Tab E to stop vibrating every 30 seconds ???
It drives other people mad as well :>)
Look at this video
https://www.youtube.com/watch?v=RQ8DLkYM9Jw
Disable Vibration Galaxy Tab Pro 8.4 - Android Forums at ...
https://forums.androidcentral.com/...galaxy-tab.../368293-disable-vibration-galaxy-ta...
Mar 6, 2014 - 10 posts - ‎8 authors
I would like to disable the vibration when I shutdown the device and the vibration all together. Can someone help me please? I Called ... New update: How do I turn off vibrate for email ...
9 Apr 2017
How Do you stop phone from vibrating when music is ...
2 Sep 2016
Any way to turn off vibration for notifications?
20 Jul 2016
How to turn of vibrate
11 Aug 2014
More results from forums.androidcentral.com
How to stop the Samsung Galaxy from vibrating - Hex Central - blogger
hexcentral.blogspot.com/2014/08/how-to-stop-samsung-galaxy-from.html Aug 8, 2014 - One of the things I dislike about my new Samsung Galaxy tablet is the way ... On other Android devices, you can disable haptic feedback from the ... For the record, my device is a Samsung Galaxy Tab 3, running Android 4.1.2.
Samsung Constantly Vibrating Fix!!! - YouTube
? 1:40
https://www.youtube.com/watch?v=RQ8DLkYM9Jw Sep 3, 2015 - Uploaded by Jimmy is Promo
If you have a Samsung device and it is constantly vibrating and you dont know why. ... my galaxy was ...
Turning off alert sounds and vibration - The Galaxy Tab Forum
www.thegalaxytabforum.com/index.php?/topic/7292-turning-off-alert...vibration/ Nov 3, 2011 - I'd like to turn off all alerts but I can't figure out how. I've only been ... Turning off alert sounds and vibration Can't get rid of continuous alerting ... See : Settings, About Device; Android Version:Unknown(SAD) - See : Settings, About Device. I'd like to ... Posted 03 November 2011 - 01:08 AM (#2) User is offline ...
How to stop conitnues vibration - The Galaxy Tab Forum
www.thegalaxytabforum.com/index.php?/topic/4195-how-to-stop...vibration/ Jun 19, 2011 - When I use my Samsung Android Tablet then it always vibrate when it keeps idle then ... Posted 19 June 2011 - 12:40 PM (#2) User is offline ...
Android Galaxy Tab to stop vibrating Google Search
Sep 22, 2017 | Tablets & eReaders
How do I fix a Samsung refrigerator that started to make noise
Noise could signal a failing or worn motor/compressor unit or falling gas pressure but it is worth checking to ensure the motor is still secure and then the fridge is perfectly level and stable.
If the fridge has been laid down, during a house move for instance, it should stand for a few hours in it's new home before being switched on. Switching on too soon can deprive the compressor of lubrication with a resulting shortened life.
Oct 05, 2015 | Samsung Refrigerators
Liebherr fridge freezer had Freon top-up to solve problem with warming up. Now there is a constant loud buzz when pump is running ( most of the time). Do I need to replace the pump/compressor?
If it ain't broke, don't fix it! If the compressor is working, leave it alone. Perhaps there is a metal panel or metal shelf inside that is vibrating from the compressor vibration.
Jan 16, 2013 | Refrigerators
Ice inside my fridge
Check door seal intact and sealing ok, clean rear compressor section of all dust/ dirt/ fluff and check drain hole on rear of fridge.as water should not pool inside but run away outside rear. Lift/ adjust door to make sure it closes properly.
May 17, 2012 | Samsung Refrigerators
Any idea on a constant F35 and F28 Code? 2 yr old
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
My 3 yr old whirlpool fridge has been constantly running for the last few days. The temps in the fridge and freezer portions are running high and the sides of the fridge are warm to the touch. What they...
" The refrigerator never cycles offThe thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
From repairclinic"
Aug 29, 2008 | Refrigerators
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Samsung RS2530BBP (25 cu ft) Side by Side Refrigerator Logo
154 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
