Question about KitchenAid KERC607 Electric Kitchen Range
Oven not generating enough heat - KitchenAid KERC607 Electric Kitchen Range
  • KitchenAid Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Aug 13, 2011
After using a generator for power my buttons quit beeping, the lower burning barely heats but the broiler works. I have a Whirlpool electric oven.
Needs a qualified electrician because your generator didnt supply enough amps for an oven.
Hard to tell how wrecked it is.
Any licensed electrician will give you an estimate for free.
Mar 18, 2014 | Kitchen Ranges
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Hope this helps.
Jun 03, 2011 | Jenn-Air Ovens
F1 error?
Hi, The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
Dec 19, 2010 | Maytag CWG3100A Gas Single Oven
My oven says F1 and it won't shut off. I have to use the breaker. What does F1 mean? What do I do? Is it an easy to fix?
Here's a simple explanation of what's going on and how to troubleshoot:
Oct 26, 2010 | Kenmore 44494 / 44495 / 44499 Electric...
I have a maytag range/oven model mgs5770adb and keep getting an F1 code on the display
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or
3. If these tests all check good, then replace the ERC.
Sep 23, 2010 | Maytag Ovens
Generator loses power under a load
A microwave oven is a fairly "reactive" load due to the current limiting transformer. You should probably have at least a 3000 watt generator to run a microwave oven.
Sep 28, 2009 | Electrical Supplies
Frigidaire gas range error message....F1
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
#$%Tf
Apr 11, 2009 | Frigidaire FGF355 Gas Kitchen Range
Micro wave not heating
Hello jrsnelus,
The main purpose of a microwave oven is to generate microwaves to heat food in the compartment so if it doesn't do that, then chances are that a component has failed. The fact that everything else seems to work suggests that you at least have ac power getting to the controls. You more than likely have a bad magnetron tube , filament transformer or high voltage capacitor that failed as part of the microwave generating system and it is not something that the untrained person should attempt to fix. Even unplugged, the high voltage capacitor remains charged up sufficiently enough to cause serious injury to someone. I've always been an advocate of the good old saying that if the cost to repair exceeds the cost to replace...then simply replace it. Even if you get an appliance tech to examine it, chances are his fee and the components that he finds defective will more than offset a replacement appliance.. I wish I could have suggested a better alternative for you..
Regards,
Rick
Nov 25, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
KitchenAid KERC607 Electric Kitchen Range Logo
157 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
