SOURCE: Replace power lead on panasonic vacuum cleaner MCE 468
Generally, there are 'hidden' screws which are found under plastic plugs. Look for them. You may also find some screws on the opposite side of the plate holding the lead. Finally, sometimes the plate will slide up or down from its fixed position. I'm not familiar with your exact unit, however.
SOURCE: Hoover 1800 telios vacuum cleaner - fuse good but does not switch
there is a button left beside of vaccuum cleaner tube to pull it up & bag will open.
SOURCE: telios 2000
This is normally caused by restricted airflow, causing the heat sensor switch to trip. Please make sure the hose and bag are not clogged, verifying you have good suction and airflow to the hose end when you initially turn it on. The heat sensor switch is intended to shut off the motor if sufficient cooling air is not present.
SOURCE: We have a Hoover Telios
It sounds like the bag holder was thrown out with the bag. The part # is 59135039, msrp $ 2.29. Check with hoover.com.
