Question about Maytag MSB2354G Side by Side Refrigerator
Maytag/Mod MSB2354GR SER # JSU18X156A0A compressor kicks on but kicks off again. after 2 or 3 seconds . on again/off again No cooling in either side Cooling fan runs all the time
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Maytag mod#MSD2550VEW00 compressor not kicking on
Could be the thermostat or defrost thermostat.
Oct 03, 2016 | Maytag Refrigerators
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Fridge cycles on and off every few seconds
sounds like the compressor can't start. could be the compressor itself, or the capacitor that kicks it on
Nov 13, 2013 | Maytag Refrigerators
Refrigerator model bx21vl does not cool. I can hear the compressor kick in but it kicks out in 5-10 seconds. Then after about 102 to one minute it kicks in and out again,
Compressor is tripping on overload. You may just need the overload and relay replaced due to a bad compressor relay. The relay is what switches the compressor from it's start winding to it's run winding. If you pull the relay off, shake it to see if you hear lots of rattling inside, that's a sure sign of a bad relay. I would replace both of them.
Here is the overload relay to order.
Here is the start relay to order.
Nov 27, 2012 | Refrigerators
Refridge or freezer not cooling evaporator fan and compressor running fan inside fridge running all inside lights on
HI welcome to fixya, THe compressor start overload is bad, They had a recall about 1-2 yrs ago. You will need a tech to replace the bad overload. Should be cheaper than a new fridgerator. And this could be under recall. You will need the frist 2 letters in ser/number I hope this helps
Sep 20, 2011 | Maytag MBR2256KES / MBL2256KES
For the second time in the 4 or 5 years that I have owned my Kenmore 16.7 upright it quit cooling altogether again -- the first time I cooled the compressor with a damp (to wet) towel and a fan, being...
If the compressor is overheating I would check the condensor fan and make sure it's turning. Sounds like you wouldn't have noticed this already though. Also, if the compressor is turning on for 5 or 10 seconds and then clicking off then your start relay is probably bad. Pull the relay off the compressor and shake it. If something is loose inside then it's bad. That is, if it's a whirlpool made kenmore. Kenmore doesn't make appliances they only brand them. The refrigerator could have been made by Whirlpool, Frigidaire, GE, LG, Maytag, Amana, or other. So, it's depenant on who made it.
Nov 24, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a Maytag Model # MSB2354GR that is not cooling. There is a humming sound every few minutes followed by a click and then the humming stops. Any idea what the problem could be?
Sounds like a simple solution in most cases. The compressor needs a little kick to get it started. That kick come from part=> number 12002783 or here=> Sea Breeze Tip's
Here is a Large view=> MSB2354GR Compressor section and on photo number 6 is the=> 12002783 Run Capacitor
p/n: 65889-4 appliance911 Part 4 in photo is=>
If you like to have how to instructions or assistance Please let me know, Thanks Sea Breeze
Sep 09, 2010 | Maytag Refrigerators
Maytag MSD2758DR side by side, not cooling at all clicking at compressor relays but compressor doesn't kick in . What do I check first?
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 12, 2010 | Maytag MSD2758G Side by Side Refrigerator
Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Maytag MSB2354G Side by Side Refrigerator Logo
200 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
