Question about General Electric WCVH6600H Front Load Washer
Where is the location of ge washing machine pump filter on a ge model wcvh600hbb
Kenmore elite model #796.2900 where is the filter by pump located
This Sears top load washer, manufactured by Frigidaire, does not have a filter like some machines. This is quite normal on many machines. Model 79629002000 KENMORE ELITE WASHING MACHINE Parts
Jul 02, 2017 | Kenmore Washing Machines
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
I cant figure out where the pump filter is on my ge washer model#wssh300goww
The pump is located bottom right in the front. There should be a panel you can take off . Three screws underneath. If I'm not mistaken there should be an access cover on that bottom panel to get to the clean out filter...good luck hope this was helpful.
Oct 20, 2010 | General Electric WSSH300G Front Load...
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Locating the filter
based on info provided your ge would be a frigidaire made machine, only filter is at drain pump. to access remove lower front access panel (screws on bottom) pump sits in middle of machine, locate large rubber hose connecting to tub, loosen clamp and pull off. inside is plastic strainer cup, empty and replace. make sure nothing went past to pump, reassemble.
Jul 19, 2009 | GE WSXH208A Front Load Washer
My ge model wbvh5200j2ww washer wont't start. it has power on the panel but doorwon't latch or start filling.
If the pump filter is clogged, the washer won't even turn on. This filter is located behind the small access panel at the bottom on the front of the washer. Remove access panel, flip down scoop, and unscrew filter. You will need a bowl to catch water that comes out(may smell bad). Pull out filter, clean, and replace. Washer should work normally afterwards.
May 01, 2009 | GE Energy Star WCVH6260F Front Load Washer
Not spinning
The belt is located in the back of the machine
You have to remove the top of the machine and then remove tha back cover. then you can see where the belt is, you will need some tools to replace the belt a socket or wrench us needed to adjust the motor pulley position so that you can get the new belt in place then you need to move it back to tighten the belt so it wont slip. its not a difficult job just make sure its disconnected from the power when you do it
Aug 22, 2008 | GE WCVH6260FWW
Wash machine agitates but won't drain the water -- on any cycle choice. Machine makes noise like something is happening, but water remains.
Yes, the problem is the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Jul 07, 2008 | GE WCVH6260FWW
Washing machine
Your outlet filter is blocked, check this out and clean it and refit. The filter requires periodic cleaning according to your use. For most machines the filter door is at the front bottom; just look for it in your users' manual.
Jun 20, 2007 | GE WPXH214A Front Load Washer
Open Questions:
See all General Electric WCVH6600H Front Load Washer Questions
General Electric WCVH6600H Front Load Washer Logo
247 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
