Question about Cycling
We took the handlebar off to move. Now I cannot get the bolt that holds it on to screw back in. How do I get it started? I cannot see a nut inside the housing.
    Brigadier General:
  • 8,546 Answers
  • 843 Answers
I assume the bolt you are trying to start is the long bolt that goes down through the vertical handle-bar stem. This bolt screws into a wedge shaped nut. Normally you don't remove this bolt, but you just loosen it, leaving the nut still attached. The wedge nut is still down in there, but it is probably loose and should fall out if you turn the bike upside down. If it doesn't fall out, you can probably fish it out with a piece of stiff wire. Good luck, Al K
Posted on Mar 15, 2011
  • 1 more comment
  • Travis Pederson Mar 15, 2011
    Thank you Al. Yes, it is that long bolt. I have been fishing around, but have not yet been able to grab it (I can't really even see it with a flashlight). I first tried turning it upside down to see if it would fall out, but nothing came out. Will keep trying, though. Really appreciate your advice.
    Travis
  • Al Kupchella
    Al Kupchella Mar 15, 2011
    On many bikes, there is a small hole at the bottom of the tube you are trying to fish the nut out of. If you remove the front wheel you should be able to push a stiff wire up through this hole. To help you visualize where this hole is, imagine peering down into the tube from the top - with enough light and no wedge nut blocking your view, you would be able to see a tiny patch of the front tire through the little hole at the bottom.
    Mine does not have that. There is a bolt which passes thru the tube that holds the forks in place, and a smaller bolt below that one that holds the brake arms. I cannot see the nut.
Torque setting 1999 300 ktm head &side cover
Thank you for contacting FixYa with your inquiry. I have been going over some of the inquiries that have been archieved and trying to provide solutions for those that didn't get answered. Hope this information helps.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber bottom bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nuts on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
Oct 29, 2011 | Motorcycles
Torque setting for centre nut for clutch housing
over some of the older help requests that have been archieved and
KTM Torque settings
KTM EXC Head Torque Specifications
Thanks for contacting FixYa. I was reviewing some of the older un-answered questions trying to ensure your issue has been resolved.
KTM Torque settings
  13. Shock absorber bottom Shock absorber botton bolt 60Nm 44ft lbs
  23. Other collar nutes on chassis M6 15Nm 11ft lbs
TF
Aug 26, 2011 | 2000 KTM EXC 300
CYL HEAD BOLT TORQUE SPEC AND CAM HOLDER BOLT SPECS.
KTM Torque settings
TF
Apr 28, 2011 | 2008 KTM 450 SX-F
What are the torque settings?
KTM Torque settings
TF
Mar 11, 2011 | KTM 530 EXC-R Motorcycles
Head torque specs.on 1991 KTM540 2-stroke
KTM Torque settings
TF
Sep 03, 2010 | KTM MXC 520 Racing Motorcycles
Head tourque wrench setting
KTM Torque settings
TF
Apr 19, 2010 | 2005 KTM EXC 200
What is te torque specs for the camshaft retaining bolts
KTM Torque settings
\TF
Oct 28, 2009 | 2008 KTM 450 SX-F
Loose handlebars
Easy 1 min job but an hr taking chrome off. Here is the readers digest version. Start with the headlight off first screw under light on chrome trim. then pry it off. unfasten the screws holding light on about 7 screws, then unplug light. their is a chrome piece on the top of light chrome has a nut holding it on take nut off then lift that piece off. pop the piece of plastic off the key hole it prys off two screws under it remove them. that piece of chrom has a screw in it in front of handlebars you uncovered it when you took that chrome cover piece off. JUST loosen it. Now im sure you took off your windshield before you started so now remove your bolts that hold on the quick release windshield on both sides. Your chrome nacell will now split apart to show your 4 bolds that lock down your handle bar. See I told you 1 in job but hr to take off the samn chrome. When you put that ling cover piece of chrome back on ..NOT To TiGHt or it will snap the piece the plastic goes on. Hope that helps.
Jun 19, 2009 | 2004 Harley Davidson FLHRS - FLHRSI Road...
Road King Custom 05 tightening down the handbars
Use a pocket knife to lift the nut and screw caps. They just press in with thumb pressure.
Jun 16, 2009 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Cycling Logo
52 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
